Battery Help
Discussion in 'Tech/Mech General' started by Gauntlet, Oct 19, 2014.
  1. Gauntlet
    Gauntlet Read Only Funster
    Feb 12, 2014
    78
    78
    Lanarkshire
    Any help or advise please my MH is 6 years old and has the old Battery charger which constantly charges the battery as you can't switch it off .I'm lucky if I get a season out of it I plan for the start of next year to install a smart charger (any recommendations) and fit 2 batteries my old charger has the red and black cables coming out and I assume goes to the battery also a smaller cable will that be the 12 v supply all the cables come out through graumets and the charger is sealed what connections would I require also how to link both batteries I'm sorry if this has been brought up before I can't find it anywhere all help would be appreciated
  2. funflair
    funflair Funster Life Member
    Dec 11, 2013
    4,880
    5,143
    Guisborough
    You should have mains cable in and 12 volt cables out (12 volt will be the red and black).
    When you put the new batteries in connect +ve to +ve and -ve to -ve, you will need a big fuse or two between the batteries if there is any distance between them plus decent size cable but how big depends on how big the load is that you want to pull, then fuse the battery +ve as it comes off the batteries to the van.
    To rewire the charger you need to follow where it is going at the moment but possibly upgrading the cables if you are asking it to supply twice the power that it was originally designed at, another thing is the charger going through a control panel and can that panel handle a bigger charger.
    • Like Like x 1
  3. hilldweller
    Dec 5, 2008
    26,903
    25,758
    Macclesfield
    Get on ebay and look up caravan battery chargers.
    Though at 6 YO you should have a modern charger that is safe 24/7. It could be faulty.
    • Like Like x 1
  4. Andy
    Andy Funster
    May 25, 2014
    631
    699
    East Sussex
    I'm assuming we are talking about leisure battery here ? if so, the way I understand it is that it receives a trickle charge from main battery whilst engines running, - provided main battery (which is being charged by alternator), is fully charged.
    My Hymer has an additional battery charger just for leisure battery to top it up if on reduced amperage ehu's.
    One thing that might be worth looking at, what amperage is the vehicle alternator giving out ?........I'm guessing most purpose built Mh's will be built with the realisation that a leisure battery is likely to be fitted........but maybe's not the intention of more than one. (I know in the dim distant past, alternators and I think, dynamo's could be 'rewound' to increase amp capacity..........Don't shout if I've got this wrong, - not pretending to be an expert or owt. :))
    • Like Like x 1
  5. 2bob
    2bob Funster
    Jul 8, 2008
    592
    319
    dorset
    h gaulet
    what m/h have you got
  6. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,384
    2,441
    Tunbridge Wells
    What charger have you actually got. A 6 year old MH should have a reasonably sophisticated one that has a planned charging regime. It will turn to trickle charge once the battery is full
    Just one thought. Gel and lead acid batteries have different charging regimes and most modern chargers have a switch to choose the regime to suit your battery. Is it on the correct setting?
  7. Gauntlet
    Feb 12, 2014
    78
    78
    Lanarkshire
    Bessacarr the charger is black with no on and of switch 08 model
  8. Gauntlet
    Feb 12, 2014
    78
    78
    Lanarkshire
    No switch no options
  9. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,384
    2,441
    Tunbridge Wells
    You shouldn't need an on and off switch. It should monitor the state of the batteries and decide for itself what charge is needed or not. Do you know the make of the charger?
  10. Gauntlet
    Feb 12, 2014
    78
    78
    Lanarkshire
    Il check tommorow thanks
  11. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,191
    12,551
    goole
    you beet me to it :Eeek:
  12. 2bob
    2bob Funster
    Jul 8, 2008
    592
    319
    dorset
    hi if it is a nordelettronica it could be us /a lot of trouble
  13. Gauntlet
    Feb 12, 2014
    78
    78
    Lanarkshire
    Can't find a name on it all I can tell you it's Black and I can't get access all the way round it its 7 years old
  14. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,384
    2,441
    Tunbridge Wells
    Lets make sure we are dealing with the right thing. The charger should be close to the Batteries. It should have lots of fuses on it for all the different 12V circuits. Is the black thing you refer to just the display? Don't know Bessacar at all but think it may be owned by Swift. Have I read somewhere that they use Sargeant controls and chargers?
  15. Gauntlet
    Feb 12, 2014
    78
    78
    Lanarkshire
    No all the fuses are in a different box the charger surely haven't all the fuses attached
  16. 2bob
    2bob Funster
    Jul 8, 2008
    592
    319
    dorset
    hi gaunlet been on swift talk and that say its a nordelettronica
    if you look on this site
    apuljack engineerings it should help
    about 80quid to repair
  17. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,384
    2,441
    Tunbridge Wells
    Mine has. It's a Schaudt charger that also distributes the 12V system. On the front of it are most of the 12V fuses. That make is standard in a lot of European motorhomes - mine's an Adria. Have a look at this site to explain it all, and they also repair Nordelectronica. In fact they recommend this company for the repair of all Swift units.
  18. 2bob
    2bob Funster
    Jul 8, 2008
    592
    319
    dorset
    try this one ask 4 paul
    Apuljack Engineering
    [​IMG]
    www.apuljackengineering.co.uk/
    Apuljack Engineering are Chartered Engineers and support staff with over 25 years experience in the Electronics design and repair industry. Having been ...
    Google+ page · Be the first to review
    [​IMG]
    Burton Row, Brent Knoll, Somerset TA9 4BX
    0800 078 7081
    • Like Like x 1
  19. Gauntlet
    Feb 12, 2014
    78
    78
    Lanarkshire
    I prefer my set up I have 3 units first unit 240v next to it 12 volt unit with all the fuses next to that is the Habitation battery charger the only cables coming out of that is the red and black going to the battery and a smaller cable providing a 12 volt supply if you haven't got the battery on line my charger is now 8 to 9 year old I want to change to a up to date smat charger quite a few on the market simple job to swap I don't think it would be easy job to swap the charger if it incorporated all 12 volt cabling and fuses that's my take on it I'm no expert quick question what voltage comes from a charger to the battery
  20. Gauntlet
    Feb 12, 2014
    78
    78
    Lanarkshire
    Thanks for that I think I'm going to replace the charger to a smart one because of age
