The Lobster
- Aug 13, 2011
- 321
- 325
- Bürstner A576
- Still getting started
I'm using the varta agm on the gel setting. The factory fitted battery was an agm and the charger was set to gel so I've left it like this. It technically isn't correct and means I probably won't get as long out of it as I should but it's doing ok at the moment (hope I've not jinxed it now!).
This is an excellent thread that discusses why AGM batteries are a waste of time (worse than that - potentially damage causing) unless the charges supports them, and argues how the "gel" setting simply causes charging to take a very long time and in any case never completely charges the battery!
Link Removed
It also discusses an issue with Hymer fitting AGM batteries as original equipment despite the charger not supporting them... and this is an interesting article from a company that repairs lots of EBL99 controllers for people who've fitted the wrong batteries - their recommendation is the Varta dual purpose LFD90.
http://www.aandncaravanservices.co.uk/battery-technology.php
So... after going round in quite a few circles, my conclusion is:
- I use an EBL99 control block - this doesn't support AGM charging and using Gel setting isn't advised for various reasons - so AGM is out;
- The Varta dual purpose range use Varta's "Powerframe" tech that appears to have lots of benefit in this application - despite coming originally from their "Starter" range;
- From various sources Varta appears to be much longer life at not much more cost than the myriad of cheaper brands
- So Varta dual purpose (LFD range it is.
