Battery died. Nae joy. (1 Viewer)
Oct 2, 2011
864
571
Scotland
Since 2011
first outing this year wilding. After about 3 hours the leisure battery was dead. Seemed healthy in November at the hab check when it was tested and was fully charged on arrival. Was just running the usual. Minimum lights and telly. Looks like a trip to Kirkcaldy caravans today for a new leisure battery. Just a thought. How long could I safely run things off the engine battery before I run the risk of not starting the engine? TIA
MC 55 FUN
3,432
6,347
Rural South West Wales.
2015 Majestic 195
Since 20th Feb' 2016
That depends on the ah of the engine battery, it's state of charge & how much current your habitation devices are drawing & for how long - in short probably not very long at all.
gordoncbrown
Oct 2, 2011
864
571
Scotland
Since 2011
Not very long was what i was thinking as well.
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
If you need anything that you think will take a lot of power run the engine while using it.
I do this when starting our diesel heater because of the high initial power needed to start it.
denisejoe
5,617
12,051
Warden isle of sheppy
Since 2004
Will your engine battery work anything our habitation area only works of leisure battery
Joe
Feb 24, 2013
13,080
101,443
Bolsover, Derbyshire
Hymer S800
not long enough
Having flattened my cab battery a couple too many times doing more or less what you are proposing I would say don't do it at all
Does your leisure battery charge when engine is running? I presume it does from your comment that you arrived fully charged, then as above stick with leisure battery and run engine (y) I was amazed how much power it put in quite quickly, and it warms the MH as well
May 7, 2013
845
1,353
RUK
On our 2nd MH now a AutoTrail Savannah which we're absolutely delighted with
If you do require a new battery have a look at BatteryMegastore -Much cheaper than most if not all caravan dealers and delivered with 4 yr warranty, to your door, next day.
gordoncbrown
Oct 2, 2011
864
571
Scotland
Since 2011
Thank for everyone's replies. Wilding again tonight so trying out the new battery. Unfortunately needed it quicker than battery megastore but will bear that in mind for the future.
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
5 years, feel free to ask me about the Carado!!
If it goes bad again try the parasitic drain test with a multimeter.
