Battery Confusion (2 Viewers)
Nov 13, 2013
488
431
Bideford, Devon
Benimar Tessora 487
since 2011
I've been looking at different batteries and more or less decided on an AGM which is very expensive but should I opt for a cheaper 'sealed' battery? I've got dual setting on my charger would a sealed until need to be set on Gel? I'm trying to avoid the venting type wet battery. It's all too much.... just to buy a battery!!
scotjimland
2,256
9,780
A Woosh bang
no.. it's the same setting as a 'wet'
whether you buy AGM or cheaper FLA (flooded lead acid) is up to you.. and your budget..
personally I always buy cheap FLAs.. they may not have as long a life as an AGM but are lot cheaper to replace.. 'bang for buck' hard to beat
If I were spending more on a battery it would be for a flooded deep cycle battery.. such as Trojan
now you will get a dozen or more posts all with different opinions.. confusing , isn't it..
Lenny HB
53,321
149,532
On the coast in West Sussex
Hymer B678 DL
You don't say what your usage is, if you spend a lot of time off grid a Gel would be a good choice as they can take an 80% DOD but they take twice as long to re-charge as a wet cell, AMG is a half way house the DOD is not quite as good as a Gel but better than a wet cell, a wet cell.
If you go for a AGM most manufacturers recommend the Gel setting on the charger (check with battery manufacturer), however set to Gel the AGM battery will never quite reach a full charge, however in the Gel setting the charger holds the max voltage for longer so in practice it makes little difference.
For example an Elektroblock charger in wet cell seting charges to 14.3v holds at 14.3 for 1hour then reduces to 13.8v, in Gel mode it charges to 14.3v holds at 14.3v for 8 hours then reduces to 13.8v. An AGM battery needs 14.8v to fully charges.
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
I have two Victron 130 amp AGM deep cycle batteries and have my m/home charger set to gel and my solar controller set to sealed.
maxine and jo
152
184
c class
since 1980
For of grid use traction wet are the best Trojan.Rolls and other similar golf buggy are ok or ups
jemhorn
Nov 13, 2013
488
431
Bideford, Devon
Benimar Tessora 487
since 2011
Delivered as per ordered, fixed in, nice snug fit all fine. Now have 2 x Varta LFD 75 on eBay
