Battery charging (1 Viewer)
H
herisson
Can anybody tell me why if I am plugged into mains supply the house battery is not charged. I was always under the impression that the splitter was able to work both ways & keep both batteries charged. Also, if left for a longish period the power in the house battery drops but even after recharging to full I need to start the motor to trigger it into action, without doing that all 12V power is off.
I am baffled by this, and any suggestions or advice will be appreciated
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
Your EHU will or should charge your liesure battery. It will not charge your engine battery. I'm not sure what engine you say you need to start to enable your liesure battery to function. You shoudnt need any engine running to enable your liesure battery.
Your liesure battery will only function when you are not hooked up or when your engine or genny are not running as they will overide your liesure battery and provide habitat power.
I hope that I have read you post correctley and that this is of some help.
Jim :Smile:
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
Hi herisson,your post is confussing ::bigsmile: but this is the best I can say :ROFLMAO:
the rely (if you have one) works only when the engine is running charging both engine and habitation batterys and if you have a twin relay will also power the fridge on 12v.OR engine and fridge ? After that 240 hook up should power your onboard charger to charge hab batt or again it may have a switch to charge either engine or hab battery?:ROFLMAO:hope this clarifys the mud :thumb::ROFLMAO:
terry
H
herisson
thankyou both for the info. I will try various solutions including unplugging. This is my third Camping car ( as we call them here in France ) & each one has had a different system - nothing seems to be standardised.
Thanks again, - H
T
tdmyoung
battery probs
i have a similar problem, my leisure battery is brand new, to charge it i selected charger on, left it 36hrs and the power was down, the van battery was almost flat, it seemed both batteries were discharging, the leisure battery was half charged when fitted. Its a pms3v/h system. totally confused, new to this.
43,319
49,387
your charger/power supply may have an on/off switch for the charger circuit while on hookup....mine does.
mines a simple illuminated rocker switch on the charger.
worth checking it hasnt been turned off by mistake.
john
