Battery charging (1 Viewer)
pvw10
273
45
Gloucester
Coach built
since 2011 after tugging.
Could somebody confirm that when i am connected to 240v the charging system charges both the engine and leisure battery pls ?
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
If you're not sure get a five quid multimeter off eBay and test the battery terminals. It's worth having one in the van anyway, in case you think something electrical's not working properly.
pvw10
pvw10
273
45
Gloucester
Coach built
Hi and cheers.
Yes i have a couple of them but was being lazy :RollEyes:
joinerderby
30
35
Stockport
auto trail cheyenne 860d
since 2012
I think my Ducato van only charges the leisure battery's if you look on the panel it will say how much charge is in each and the veicle battery never seems to go up.
jb0371old
465
408
Norfolk
Autotrail
1 year
In my autotrail to charge up the engine battery, turn on the control panel and also press the battery button, then turn on the main changing unit.
pvw10
pvw10
273
45
Gloucester
Coach built
Mmm thats a new one, will try cheers.
Nice to see your "Help for Heroes" fella.
Feb 27, 2011
14,703
75,632
UK
Self Build
Neither my Hymer nor my Eura charged the engine battery if I recall correctly.
pvw10
pvw10
273
45
Gloucester
Coach built
Thats what i keep wondering. On mains now yet only showing charge on liesure battery.
flatpackchicken
1,277
1,757
BICESTER OXFORDSHIRE
A Class Frankia I8000
Since nov 2009
Hi mate, Not many motorhomes charge both engine and leisure batters on EHU, normaly only leisure charges unless you have something extra fitted to your system that allows for both to be charges simutainesly, only the engine charges both batterys, even my m/h only charges the leisure battery when on EHU, sounds like you need some gadget to be able to charge both when on EHU or even solar. Regards Garry Flatpackchicken
Jan 27, 2009
872
3,358
Leyland Lancs
since 2001
Can't speak for all Hymer models, but the B544 (2004) charges both leisure and starter batteries when on EHU. The leisure battery gets about 14v and the starter battery about 13v.
mikebeaches
5,390
8,588
Bristol
Rapido V68 Van Conversion
Since 2009
Our 2010 Chausson Flash S2 only charges leisure battery on hook-up, but our previous 2004 Rapido, did the cab battery too. :thumb:
Mike
Daveo2006
1,164
998
kent
Apache 700
3 years
On my van the leisure batteries are charged and when full switches over to the vehicle battery.It can be changed over by pushing button on control panel.
maz
Jan 26, 2011
4,459
7,735
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Seems to be a movable feast, as both my current Hobby and previous Burstner charged both engine and leisure batteries on hook-up automatically without the need for any switching. :Smile:
JockandRita
11,445
149,741
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
And our 99 Hymer E690 is exactly the same, and all MH makes mentioned in the above two quotes have the Schaudt Elektrobloc fitted, which charges both banks of batteries simultaneously. Ours is a 16 A charger, but I believe the newer models have a higher charge rating.
The pressing of the rocker switch for Batt 1 or Batt 2 (Schaudt panels) indicates the charging voltage for each bank. When not on charge, the same switch indicates the actual voltage in each bank.
I am sure that the Schaudt systems are not fitted to UK built MHs. Zig, Sargent, CEC, and Plug In Systems, are the only ones I am aware of.
Regards,
Jock.
