battery charging
Discussion in 'Tech/Mech General' started by peaps, Apr 6, 2008.
  1. peaps
    peaps Funster
    Feb 3, 2008
    161
    25
    SWINDON
    Hi wonder if any of you guys out there can help.
    I've just discovered that my coach battery isn't charging when the engine is running,the only way I can get it to charge is by holding the emergency start button on.Any suggestions would be greatly appreciated.
    Pete
  2. johnsandywhite
    johnsandywhite Read Only Funster
    Jul 29, 2007
    2,348
    15
    Doncaster/Spain
    :Cool: Hi peaps. It sounds like the Relay/Solenoid is not working. It should kick in once the Motor battery has recovered sufficient charge. I had this happen on our Newmar while in the USA. :Wink:
  3. peaps
    peaps Funster
    Feb 3, 2008
    161
    25
    SWINDON
    thanks for that .
    I had a feeling it would be something like that just didn't want it to be, whoever owned the van before me has created a spaghetti nightmare behind the dash.Looks like I have to get the schematic out.
    cheers
    Pete:thumb:
  4. Digger Driver
    Digger Driver Read Only Funster
    Oct 4, 2007
    578
    Lancashire
    I had the same trouble with mine and it turned out to be a loose wire on the Zig unit!
    I traced the circuit back with a multi-tester from both ends!
    Just a thought!
  5. johnsandywhite
    Jul 29, 2007
    2,348
    15
    Doncaster/Spain
    :RollEyes: I think it might be a little different on an RV. They don't usually have Zig units fitted. :Wink:
  6. olley
    olley Funster
    Jul 29, 2007
    3,840
    2,392
    Ipswich
    Hi Pete mines wired straight from the ignition switch, as soon as you turn on the ignition it energises the relay. As john says others are different, having either time or voltage delays.
    Olley
