Battery Charging with a Generator
Discussion in 'Tech/Mech General' started by lunarman, Jul 31, 2009.
  1. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,468
    881
    South Glos
    I have a Kawasaki 700w suitcase generator that has both 240 and 12 v outputs I can use it to charge the batteries via the 240v ehu and on board charger but would it charge quicker using the 12v output and if so would I need to connect it via some form of charge controller?
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,689
    5,843
    Mansfield,Notts
    It will charge more efficiantly going direct to the battery,
    check the genny spec for its charging rates it proberbly has a built in reg, given the time it will spend charging i wouldn't worry
    Geo
  3. lunarman
    Sep 23, 2008
    1,468
    881
    South Glos
    Thanks Geo,
    Its rated at 12v 8.5A (suitable for battery charging) with an Automatic Voltage Regulator.
    Do I just connect the Gennie to the battery without isolating the batteries or any internal wiring.
    Lunarman
  4. Braunston
    Braunston Read Only Funster
    May 21, 2008
    1,415
    7
  5. Frankia
    Frankia Read Only Funster
    Sep 24, 2007
    133
    Lincolnshire
    I have a Honda with a similar 12v out. In the 'van we also have 3 leisure batteries which are wired together with the quick release battery terminals. The inbuilt charger gives about 16Ah so:
    If I want a quicker charge up I disconnect the last battery in the run and charge that from the 12v out of the Honda whilst the 230v out is on hook up to the 'van therefore charging the other 2. This gives me a charging rate of 24Ah instead of 16.
    I don't often use this method as we have 2 X 120w solar panels on the roof that for most of the time keep us adequately supplied.
  6. Tony Lee
    Tony Lee Read Only Funster
    Sep 28, 2008
    274
    Most generator 12V outputs are really intended to supply around 12V (sometimes up to 17V open circuit) to things like refrigerators and the like, rather than actually charge a flat battery.
    Just because it is marked 12V, say, 8A doesn't mean it will actually deliver that current to anything other than a dead-flat battery, so it is quite possible that even a small 3-stage mains charger could do a better job than a direct connection. Optimum might be to run any large 12V load direct from the 12V output while using the mains charger to charge the battery.
  7. teensvan
    teensvan Read Only Funster
    Jul 25, 2009
    63
    Fulltime in Motorhome
    Hi.
    We have a 2kva kipor geni. The 12 volt output charge is 8.5 Amp. If i connect it to the EHU the batteries are charged at up to 25 amp. Much better charge going through the EHU and onboard charger unit.
    steve & ann. ------- teensvan.
  8. lunarman
    Sep 23, 2008
    1,468
    881
    South Glos
    Hi Teensvan,
    I do not understand your posting how are you connecting the gennie to get 25 amp charge? It seems to say that you are connecting the 12v to the EHU.
    Lunarman
  9. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,320
    YO11 2BD
    he means connect the 230v genny to the 230v hookup socket on the van and use the onboard charger instead of the 12v facility on the genny.
  10. lunarman
    Sep 23, 2008
    1,468
    881
    South Glos
    Papajohn
    I still dont understand he says "much better than using the ehu and on board charger"!!
    Lunarman
  11. david price
    david price Read Only Funster
    Sep 28, 2008
    387
    27
    Bridgenorth
    Says much better going through the ehu and on board charger.
    Dave
  12. sandyketton
    sandyketton Read Only Funster
    Aug 29, 2007
    334
    17
    South West Suffolk
    Lunarman
    He actually said
    "Much better charge going through the EHU and onboard charger unit."
    Sandy:Smile:
  13. pappajohn
    Aug 26, 2007
    29,704
    17,320
    YO11 2BD
    think you are miss-reading the post....hes saying its much better to use the gennies 230v supply plugged into the hookup socket and use the onboard charger than the gennies 12v charger direct to the battery.
    genny power output @12v = 8.5amps onboard charger output @ 230v = 25amps
  14. hilldweller
    Dec 5, 2008
    26,886
    25,738
    Macclesfield
    There a pattern here - 12*8.5=100W. There must be a cheap 100W regulator out there that they all use.
  15. pappajohn
    Aug 26, 2007
    29,704
    17,320
    YO11 2BD
    probably just an industry standard, Brian.
  16. lunarman
    Sep 23, 2008
    1,468
    881
    South Glos
    should have gone to specsave!!
  17. sandyketton
    Aug 29, 2007
    334
    17
    South West Suffolk
    According to the handbook for my 2005 Lunar 620 the output from the regulator is
    12 volt and 12amp.
    Hope this helps
    Sandy
  18. pappajohn
    Aug 26, 2007
    29,704
    17,320
    YO11 2BD
    still better than 8.5amp though and you can run other 230v appliances at the same time.
    my onboard was rated at 12amp as well 'til i bought a 25amp three stage charger and fitted that in its place:thumb:
  19. Gonewiththewind
    Gonewiththewind Read Only Funster
    Sep 13, 2007
    854
    35
    Lancashire
    Your Adding words mate, he said "better to ":Rofl1:
    Don
