Battery charger & Solar panel
Discussion in 'Tech/Mech General' started by Mike B, Apr 21, 2015.
  1. Mike B
    Mike B Funster
    Jan 16, 2014
    794
    2,290
    Harleston, Norfolk
    Can you charge your battery with an intelligent battery charger during daylight?
    The question arises in that my solar panel is at present giving me a 14.4v/3amps (yes I know that a poor current output), will my battery charger detect the 14.4v and decide that the battery is charged?
  2. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,315
    8,026
    West Norfolk
    No, it will apply 14.4 volts until the increased resistance of the charged battery decreases the current flow to a level at which the charger is programmed to lower the output voltage.
    Will the two systems fight each other? No idea!
    It also depends on your Sargent PSU. Early versions simply put out a fixed voltage of around 14v.
    • Like it Like it x 1
  3. Mike B
    Mike B Funster
    Jan 16, 2014
    794
    2,290
    Harleston, Norfolk
    Replaced the sargent with a CTEK MXS 10 - 3 leisure batteries
  4. Mike B
    Mike B Funster
    Jan 16, 2014
    794
    2,290
    Harleston, Norfolk
    Just checked Solar output 13.4v
    Voltage at battery 13.17v
    Switched on battery/C
    voltage at battery 13.8v
    So an increase in voltage, probably an increase in charge then.
