Battery charge help? (1 Viewer)
pvw10
273
45
Gloucester
Coach built
since 2011 after tugging.
I have two leisure batteries both wired together with the Sargent add on loom you can buy. I wish to fit a trickle charger so whenever the mains is on it trickles my question is which clips go to which battery ?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Assuming you haven't already got a built in charger (Most Have) so check first
The Red clip will go on any +Terminal on either battery and the Black clip on any - Terminal on either battery.
Treat your two batteries as One Big one, with two + s and Two - s
G
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
As geo says what's wrong with the built in charger, shouldn't need another one
pvw10
pvw10
273
45
Gloucester
Coach built
The thing is pants, it's running hotter and louder than I would like it to be but had it checked it and all ok.
Just thought a fit and forget trickler better than me remembering to turn the psu on/off as I don't like this particular one being left on.
Feb 16, 2013
19,734
52,021
uttoxeter
50 years
Are the battery's ok , it's not having to work to hard to charge two battery's is it?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Hay Paul suggest you get a smart charger 4 stage pref
simple single stage will kill your batteries in no time
G
pvw10
pvw10
273
45
Gloucester
Coach built
Good shout no there both new, I bought them. They hold charge well it's just the topping up in fixing.
pvw10
pvw10
273
45
Gloucester
Coach built
G
Only Ctek for me, as I have Italian bikes you find the best chargers he he
Sep 16, 2013
2,219
7,937
Horncastle, UK
Van Conversion
Since 2006
Negative to negative on one of the batteries, positive to the positive on the other.
This will give a more even charge.
Edit: This is also the best way to have your electrics connected to the batteries as it gives an even dis-charge as well.
