Battery cable size (1 Viewer)
Bruce
147
51
Glasgow
AUTOSLEEPER FLAIR
TWO YEARS
Hi I am almost ready to install a zig cf9 unit to my campervan and was n`t surprised at the price of cable.(Especially Maplins wow they can charge)
However somebody said that I could use 4mm sq solar panel copper cable between the main battery and the leisure battery. Not convinced but would be miles cheaper Any comments appreciated I am new to this so please tolerate my ignorance Also any other help with installation procedure. 24 volt hookup and RCD unit already in(10amp and5 amp) I will only be running 12volt switched lights ,water pump etc from 12volt side.........Thanks Bruce
sedge
Jul 7, 2009
5,502
13,085
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
Hee hee, why do you need to be knowing that Bruce? Your info panel says you haven't got a M/H ! :Smile:
Bruce
Bruce
147
51
Glasgow
AUTOSLEEPER FLAIR
TWO YEARS
HEE HEE I HAVE NOW. A TRANSIT MINIBUS NOW MINUS SEATS. BULKHEAD FITTED BEDS INSTALLED SINK AND HOB KITCHEN UNIT NEARLY READY SITTING IN LIVING ROOM WITH MILLIONS OF OTHER BITS AND PIECES(WIFE ON VALLIUM) SO ANY HELP PLEASE AS I WANT TO DO THE WIRING BEFORE EVERYTHING IS IN
REGARDS BRUCE
ps will change info panel
Bruce
Bruce
147
51
Glasgow
AUTOSLEEPER FLAIR
TWO YEARS
Toby transit
Hi hee hee now have transit hi cube minibus for converting to camper updated profile but still finding my way about site will post pics when i know how
scotjimland
2,259
9,787
A Woosh bang
Hi Bruce
to answer the fist question..
The cable size must be calculated, to do so.. what is your ..>
1. Max Current in Amps.
2. Cable length in meters.
From these two factors use this calculator to determine the correct size..
http://www.solar-wind.co.uk/cable-sizing-DC-cables.html
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Quite often the cheapest way to buy big cables is to buy Jump leads of e-bay and cut the clamps off:thumb::thumb:
11,842
14,068
Eastbourne East Sussex
Hymer low profile
Since 1972
I've noticed that, also a cheap way to get 3core 13A cable is to buy an extension lead and cut the ends off. 5m extension lead £1.99, cable 80p/m i.e. £4 for 5m.
