Hi all, i am going to add 2 new 110ah batteries, under side seat and require a box/s, but do not want to buy them over priced things, what do you use and where from regards BAZ.
i have sat our battery on a sheet of rubber to take any shock out, other than that just make sure they are secure and make sure nothing can make contact with the terminals
Provided there is nothing else stored in the under seat box I would agree with John.. but if you store other kit in the same box I would suggest fitting a plywood dividing wall with a top lid over the batteries, the last thing you want is a metal object sliding over the battery terminals.
Even with vent pipes, the battery box should be vented to the outside of the van and sealed to prevent gas escaping into the van..
