battery boiling
Discussion in 'Motorhome Chat' started by david price, Sep 28, 2009.
  1. david price
    david price Read Only Funster
    Sep 28, 2008
    387
    27
    Bridgenorth
    Funny smell in van today and after searching found it was coming from one of the hab batteries.
    It was very hot and liquid inside was boiling.I topped it up a couple of days ago when it was pretty dry.
    Does this mean new battery required?
    dave
  2. hilldweller
    Dec 5, 2008
    26,910
    25,761
    Macclesfield
    More likely a new charger - you need to measure the voltage. FAST.
  3. Nexus
    Nexus Read Only Funster
    Aug 10, 2009
    22
    West Sussex
    David,
    If the smell is a bit like a catalytic converter or acidic and the liquid is boiling then I suggest you look at the regulator urgently. It is over charging and is going to ruin your battery if it has not done so already. Be careful, you are dealing with a solution of sulphuric acid.
    BrianG
  4. tofo
    tofo Funster
    Oct 1, 2007
    6,647
    6,384
    Kirby cross further from londin
    i have had the same in the works van
    ended up new battery that cured it
    what you smell is a highly flammable gas
    and i believe hydrochloride gas
    i suppose somone will correct me
    it still isnt a nice smell though
  5. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    Hi David
    I had the same over in France last year, boiled its head off and stunk the van out, I had 2 batts in tandem so just disconnected it and replaced it on the return to uk, no further troubles after that so charger etc must have been ok, I was hooked up on a camp site the only other thing I was doing was charging a 12v batt charger engine starter, I always wondered if that was anything to do with it but as I don't know much about these things I can't say. Did you have anything else going on ?. Pete:Eeek:
  6. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    A new battery WOULD cure it for a while but the advice is right.
    Check the charger/charging voltage before you end up with another scrap battery.
    Better safe than sorry.That gas is quite intoxicating and possibly explosive in a confined space....Like when you're asleep in the van.
    Don't want to scare you but best get it checked out.
  7. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Hi I agree with your advice but it was over 18 months ago I had my trouble, I don't have the van now so I can't check. I traded in so I hope it ok but after 18 months id had no further troubles. pete
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    if its only one battery then that battery has a very high internal resistance and is knackered.
    easiest way to describe the smell is rotton eggs.....thats the sulphuric acid overheating and releasing sulpher gas.
  9. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Hi John..
    Still better replaced than gassing ......
    I agree it's not a pleasant smell.
    Woke to it once and it was a combination of battery and charger..
    For safety replace battery and monitor charge volts/amps especially if on EHU with the charger replenishing batteries overnight.:thumb:
    Battery was hot and cells had no electrolyte left.....
  10. pappajohn
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    did someone mention......gassing!!!!
  11. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Shhhhhhhhhh I smell a Rat Or........:Doh:
    Smells worse than a night out with a vindaloo.....
  12. pappajohn
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    i once melted a battery.......6v bike battery on a 12v charger at 15amps:Eeek:
    forgot to switch to 6v. :Doh:
    only took a couple of hours to reduce it to a plastic blob.
  13. david price
    Sep 28, 2008
    387
    27
    Bridgenorth
    Hi all,thankyou for the replies.
    I have two batteries in tandam and only the one getting hot.I shall be checking after work.
    dave
  14. pudseykeith
    pudseykeith Read Only Funster
    Nov 5, 2007
    382
    105
    Leeds West Riding of York
    Hi Dave.
    Get the area where the batteries are WELL ventalated. Don't use an electric driven blower. The smell is gas, and highly explosive. The fumes and liquid coming from the battery is very corrosive and will start to corrode anything they come into contact with. Disconnect the 'earth lead' first, and get that battery out of your rig. If there are signs of corrosion, wash it down with hot water and dry well. Coat affected areas with vaserline. Wash any material affected. Be very careful, batteries can and do explode. You need a new battery. If Geo responds to your post, follow his instruction.
    Pudseykeith :thumb:
  15. david price
    Sep 28, 2008
    387
    27
    Bridgenorth
    Hi all ,just checked batteries.Without charger on 12.7 volt,put charger on and it goes quite quickly to 13.8volt.
    The charger is a nordelettronica model no ne143mh.Will leave on for a while and keep checking the battery that got hot.
    dave
  16. david price
    Sep 28, 2008
    387
    27
    Bridgenorth
    One battery still getting hot so have removed,other one reading 14.3 under charge so looks like batterie kaput.Will keep eye on it but charger seems ok.
    Dave
  17. hilldweller
    Dec 5, 2008
    26,910
    25,761
    Macclesfield
    You've convinced me.
  18. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,679
    5,833
    Mansfield,Notts
    I will be convinced, when the chargers output has been proved within tolerance
    dont ignore advise to check it, as the remaining "good battery" may just be tollerating(for now) an over charge fault as has been suggested :thumb:
    Geo
