battery advise please (1 Viewer)
goffer
15
weymouth sunny dorset
c class
2 but tugged for 10
I want to add another 12Volt 110 amp battery to my system to give me longer power when not on hook up.especially now that winter is approaching but need the following advise
(1) Will it be worth it
(2) To connect two together is it POS to POS and NEG to NEG
(3) What thickness of wire will I need
(4) Then is it Normal Connection to the system POS and NEG
(5) Will the present Charger be suffice
Any advise will greatly appreciated
Tony
Terry
11,932
9,068
Lincolnshire
Can't remember ;)
1= yes
2= yes
3= thicker the better - same as to your battery earth strap
4= yes
5= what charger do you have? something around 20 amps or bigger would be great
terry
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
Tony
1/ Only you can answer that
2/ Yes
3/ the thinner of the starter cables will be fine
4/ Dont understand you question
5/ you do not give the details of your charger.
Doug...
Sep 29, 2007
796
1,155
Wantage, UK
Motorhoming since 2006, 30 years tent camping in Africa
To add to what Terry said about thickness.
I agree with him, the thicker the better. But where does it become overkill (i.e. anything bigger than 25mm is going to be HUGE and difficult to work). My advice - get a 16mm jumper set and cut it up.
If you were going for several batteries and an inverter greater and 1kw I would say you want at least 16mm but I use 25mm (partly because I have a Sterling B-2-B charger and my cable is quite long).
Another option is to go to someone like MDC and get those ready-made battery cables. I think they are about 16mm. Over a short distance (i.e. 50cm) 16mm can handle a very big load. With 12v your cable distance is very important.
Rog
G
goffer
15
c class
2 but tugged for 10
Battery Advise
Thanks chaps, my charger is the normal Elldiss in motorhome charger dont really know what it is, but it charges the one battery ok plus I have a 28watt solar panel
Tony:thumb:
43,319
49,372
simple wiring diagram.
