Batteries fully charged (1 Viewer)
Shirley
16
6
Stockport
Fiat Ducato
New
But no power going into the lights etc, checked fuses all ok ? Any ideas X
MannClan
225
231
Peterborough
coachbuild
approx 2003
Shirley
I am sure someone will be able to help you but they will need a bit more info ie: type of van, model, year etc etc
cheers
dave
Feb 9, 2008
8,945
18,698
Corby, Northants
Coach Built
Some modern vans/Motorhomes have a kill switch (Autotrails) which cuts power to all services. Try switching it on if this is the case. Do you have a manual for your motorhome. If so, give it a read, there quite helpful.
Apr 25, 2012
794
826
Near Truro, Cornwall
Hi Shirley, you say batteries fully charged, which implies your control panel is showing a healthy reading is that for both the engine and habitation batteries?
You say no lights, etc. Do you mean external vehicle lights, or internal living area, or both?
Are you hooked up to mains supply?
You say you have checked all the fuses and all are Ok, I assume you mean the fuses on the Electroblock?
Do any of the internal bits work? Eg water pump, 240v sockets?
The only time I have anything like that happen to me was with our first van, on its first outing, when the Electroblock itself failed.
Have you by any chance switched off the Electroblock connection to the leisure batteries? My Electroblock has a "batterie ein, batterie aus" rocker switch.
Start again at the beginning and work through the lot, the. Post again. Gary
Flook
553
467
Chelveston, Northants
Elddis Autoquest 175
Since 4th January 2015, first registered in January
Silly question, with your ignition key in, turn the key to start up, does the battery turn over the engine Y/N, if no then the battery may be US if it shows as being fully charged, if it does then check out your external lights, also check your main power bank that has all the switches, and turn the main on/off switch to on. Then check your internal lights etc. Meanwhile your engine is charging your batteries while it is running.
Flooks
Langtoftlad
8,861
150,689
Langtoft, South Lincs
WildAx Aurora FB [PVC]
Since 2015
g8ysn
638
417
ng219ep
coachbuilt
If no 12volt try disconnecting main display allow few minutes then re connect like a computer needs booting this was an issue l experienced mine has 3 connectors
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
You really need to tell us what kind of motorhome you have and, ideally, what charging system it has. I know you have replied 'Fiat Ducato' in another thread on this same subject, but that is not a type of motorhome; it is the make of the base chassis. What is the motorhome name/make and model? (e.g. make: Swift, Hymer, Autocruise / model: Bolero, B544, Wentworth etc.)
JeanLuc
3,304
2,199
Warwickshire
OK so have we any knowledgable Rollerteam owners who can advise her then.
DanielFord
3,020
3,086
Might be a silly question, but I always go for the obvious first. Is the cabin light switched on?
