Batteries Again!
Discussion in 'Motorhome Chat' started by hdvrod, Feb 5, 2013.
  1. hdvrod
    hdvrod Read Only Funster
    Dec 27, 2011
    860
    739
    devon
  2. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,333
    8,064
    Norfolk
    Yes, a very good article. Forget the bit about traction monoblocs being too expensive, 50% over the cost of a leisure battery will get you a good traction battery.
    Sterling's charging systems are excellent and work very well on motorhomes as well as boats.:thumb:
  3. Phill D
    Phill D Read Only Funster
    Dec 6, 2011
    4,414
    4,633
    South Wales
    Good read. I have a simple question though.... my van is fitted with a Gel leisure battery as standard, it is located under a bench seat . I believe a Gel battery is used because it is located inside the vehicle and does not require a ventilation system. I believe if i was to substitute a lead acid battery it would need to be in a sealed box with an effective ventilation system.
    Is that true?
  4. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,333
    8,064
    Norfolk
    It depends how well ventilated it is.
    Ventilation can be to the inside of the van without problems so long as the volume of air can absorb the battery gas whilst keeping the concentrations to a low level.
    Ford fit batteries under the seats of the Transit as standard, they have obviously assessed the risk before doing so and have no problems.
    Our motorhome has batteries under both cab seats and 2 more in the garage. We have never noted any buildup of odours due to the large volumes in which they are sited. Nor have we had any explosions!:BigGrin:
    As long as your battery is adequately vented into a large volume of air, internally or externally, I wouldn't be too paranoid.
    HOWEVER, if your battery is inside a locker or under a seat box, a dangerous concentration of hydrogen could build up causing an explosion hazard.:Eeek:
    Common sense should prevail here!
    • Like it Like it x 1
  5. FULL TIMER
    FULL TIMER Read Only Funster
    May 31, 2012
    796
    712
    NORWICH
    The article is very informative as you say and the advice of which I have followed for many years, have dealt with Sterling many times in the past especially when building vehicles for the emergency services and local authorities. Sterling Power are good people to deal with and their products are excellent quality.
  6. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,818
    1,032
    Cark, Cumbria
    I've seen this before & yes it's interesting. We have two 110amp "leisure" batteries which we bought at a show three years ago for £50 each when the battery on our previous van died without warning. We swapped them to the "new" van & they have worked well so far but are probably nearing the end of their life, so the question is where can I get the equivelent in traction batteries that will fit in the same space without re-mortgaging the house?
  7. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,333
    8,064
    Norfolk
    Simples-
    http://www.justcarbatteries.co.uk/index.php/specialist-batteries/dyno-specialist-batteries.html
    http://www.justcarbatteries.co.uk/index.php/specialist-batteries/trojan-specialist-batteries.html
    There's bound to be something here that'll fit!
    I can vouch for the Dynos, very good value for money!:thumb:
  8. hilldweller
    Dec 5, 2008
    27,885
    26,962
    Macclesfield
    >>> Batteries Again!
    Yea gods no, I can't take another thread like your last one.
    • Like it Like it x 2
