Batteries again !! (1 Viewer)
Taffand Dawn
14
Hampshire/Cornwall
E350 7.3 Gulfstream Ultra
Well after removing the 2 aaa batts:Eeek: from the engine bay and replacing them with manly ones:thumb: i now have 2 to use as leisures for the wifes precious mains lamp:Doh: !! so via an inverter, is it best to wire in series or parrallel ? Am i right in thinking parrallel ?
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
if 12V batteries in parallel or you will end up with 24V, if 6V then in series to give 12V
Why on earth are you using a mains lamp, change the plug an bulb to 12V (preferably LED's)
Nov 6, 2008
3,943
40,801
Ramsey, Isle of Man.
Coachmen Concord 300TS
8 years with an RV
In parallel you end up with the same voltage , in series you end up with twice the voltage.
Craig
Taffand Dawn
Taffand Dawn
14
Hampshire/Cornwall
A pretty little normal mains lamp she likes it and its been in the van for ages I used to run it via the lighter socket and inverter oh Dawn doesnt like led,s
scotjimland
2,262
9,794
A Woosh bang
well, I can understand not liking LEDs . neither do I.. too cold and makes it feel like an operating theatre ..
why not convert the lamp to 12v ? Or buy a new 12v one... go on, you know you should.. :winky:
Taffand Dawn
Taffand Dawn
14
Hampshire/Cornwall
Lamps
We used to have 12v lamps that looked quite good maybe a bit old fashioned looking but made of pot and frilly shades :ROFLMAO:but havent seen any for a while do you know if they are still available then ??:thumb:
stcyr
1,765
1,160
Normandie
On & off, since 1966 - fulltime since 2005
Sure I saw some on ebay the other day ... in 'motorhome spares' section :Smile:
scotjimland
2,262
9,794
A Woosh bang
hmm.. good question, frankly not recently.. well, not the old fashioned ones that every caravan used to have.. most have moved onto spot lights with either halogen or LED lamps.. or fluorescent strip lights..
all I can suggest is to try your local caravan dealer.. or have it converted by fitting a 12v lamp holder.. shouldn't be too difficult ..
Other option is to look for a halogen desk/table lamp, one that has the '230v/12v transformer in place of a 13amp plug .. cut it off and fit a 12v plug
