"Batt" symbol on dashboard
Discussion in 'Peugeot' started by gavel, Mar 26, 2014.
  1. gavel
    gavel Read Only Funster
    Feb 15, 2009
    20
    East Anglia
    Whenever I start the engine "batt" appears on the dashboard and the instruments behave very stiffly. The battery is up to full strength and the engine starts. What could be the problem? Thanks.
  2. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,567
    9,991
    the alternator and charging circuit may well be faulty, especially if the Batt light remains on after the engine has started
  3. TheBig1
    Nov 27, 2011
    7,567
    9,991
    sorry should have said make sure the earth strap to the engine and gearbox is not corroded
  4. Larby
    Larby Funster
    Jun 17, 2012
    1,718
    3,993
    North Essex
    Both suggestions by The Big1 are worth looking at.
    I had total power loss last year due to bad/corroded connections to 12v system. Not sure of your vehicle but mine is the wonderfully :Eeek: located fuse board on the battery on my Fiat Ducato.
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,952
    17,623
    YO11 2BD
    put a volt meter across the battery with the ignition off and note voltage.
    start engine and do the same again.
    same volts....alternator not working
    rise in volts....alternator ok and a fault on the exciter circuit (batt light circuit)
    if the engine is a quick starter then you may have quite a few starts before the battery is too low to turn the engine.
  6. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    That is normal, unless you mean that the battery light comes on AFTER you start the engine.
    If everything is working, the battery light comes on when the alternator is not spun up, but the ignition is on. i.e. before and during engine start, but should turn off within a second of the engine catching.
  7. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    As it is a motor home it's worth noting the split charge / 12volt fridge circuit could be also part of the problem after all they are linked into the alternator / charging system.
Similar Threads
  1. Melvin
    7
    474
  2. gordoncbrown
    658
