Bathroom Water 1999 Citroen La Strada Avanti (1 Viewer)
K3n
16
Cornwall
Van conversion
Newbie
Hi all,
I'm a newbie with a 1999 La Strada Avanti on a Citroen Relay base. Picked it up last week and am now sitting in it on the drive trying to work everything out!
The thing that's bothering me most right now is I can't get any water flowing through the bathroom sink tap/shower head. I've got the power on and the water pump at the control panel, the kitchen taps are working and the toilet flushes, but just a very occasional drip from the shower. I've had a look under the sink and can't find a valve of any sort. What am I missing? Any ideas?
If there are any other La Strada owners hear I'd love to hear from you!
Ken.
Lenny HB
52,710
147,676
On the coast in West Sussex
Hymer B678 DL
Could be a faulty tap micro switch (don't think they use a pressure switch in your van).
Try turning turning on kitchen tap then shower tap at same tim, if water comes out shower it's the micro switch in the tap head.
K
K3n
16
Cornwall
Van conversion
Newbie
Thanks @lennyhb but I already tried that and no luck! I'm assuming it should work with just cold water - I haven't attempted the water heater yet. A ton of question about that to follow!
1,065
15,678
bedworth warks
c class
2009 previously a tugger for thirty years
Have you tried turning it all off, emptying the kitchen and basin taps then turn it back on again and turning the shower on FIRST? The shower tap was sort of the 'master tap' in our Bessacarr and if you did that first , you had absolutely NP. Just a thought.
Lenny HB
52,710
147,676
Hymer B678 DL
Assuming it has a Truma Combi, dump valve is not open buy any chance & when you turn on the tap it just pumping water out under the van, strange things happen with Truma dump valves.
Normally cold will flow even with boiler empty.
K
K3n
16
Cornwall
Van conversion
Newbie
Nope, that's not working either. But thanks for the suggestions! I'm going to move on and come back to that. So it looks like the original Carver space and water heater in my van has been replaced with a Trumatic E2400 space heater and a Truma BM10 water heater. I have the instructions for these and have made sure the drain valve is closed but, given the shower problem, how can I be sure there is water in the water heater? If I fire it up and there's no water in it that's not going to end well!
K
K3n
16
Cornwall
Van conversion
Newbie
One other thing that might be relevant. When I turn on the kitchen tap I can hear the pump going but nothing with the shower.
182
176
Merseyside
Transit coachbuilt
8years & counting
I find with mine, especially after winter drain down I have get my mouth around the kitchen tap and suck the water thru with the pump running, just seems to prime the system, once done & kitchen taps running bathroom and shower also work.
K
K3n
16
Cornwall
Van conversion
Newbie
Sorry for the delay. It wouldn't let me reply til I'd paid my ten quid. Crafty!
Anyway, it worked! but not for the reason you might think. I'm standing in the bathroom with my gob around the showerhead sucking hard and I spot something on the top of the shower head that looks like it might turn... It does turn! And water comes out. It turns one way for the inner ring of nozzles and the other way for the outer ring. I saw the mixer tap fitting on the basin, it didn't occur to me there'd be one on the shower head as well!
Thanks! @Keith777
Minxy
32,489
66,024
E Yorks
Carthago Compactline
Thanks! @Keith777
Hi Keith, welcome to the mad house! :)
You've given me a real chuckle ... and will forever be known to me as the shower sucker!!! :D
Minxy
32,489
66,024
E Yorks
No, I'm the kitchen tap sucker, it's k3n whose the shower sucker !
Oops ... too many 'k' names! At least you're a sucker too so I wasn't completely wrong!!! :D
