Bathroom doors
Discussion in 'Motorhome Chat' started by Mart grump, Apr 28, 2012.
  1. Mart grump
    Mart grump Funster
    Apr 26, 2012
    68
    6
    We have a brand new swift kontiki 669 every time we drive the bathroom door comes open the dealer said to put a catch on the outside but as we have lost confidence in them didn't think that was right considering the money we have spent any ideas ?:cry:
  2. Carol
    Carol Funster Life Member
    Oct 2, 2007
    10,440
    15,099
    North Wales.
    We have put a small magnetic catch on our bathroom door does the job fine and can't be seen.
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,693
    17,303
    YO11 2BD
    Its brand new....INSIST on it fixing by the dealer....and i don't mean a catch on the outside.
    all it will need is a bit of adjustment to the mechanism.
    • Like Like x 1
  4. MHVirgins
    MHVirgins Read Only Funster
    Aug 22, 2011
    3,890
    3,165
    South of Scotland
    We agree with pappajohn, it's new the catch should be working properly.....sling it back to your dealer:thumb:
    We weren't happy with the sealant going around our loo where it meets the inner wall, gaps here and there, so we took it back and asked for it to be sorted. The omni step kept sticking as well, so we went back about that too:Doh: I think they used to hide behind the counter anytime we went in after that, but it's brand new and should be right first time:thumb:
  5. SandJ
    SandJ Read Only Funster
    Sep 14, 2007
    1,558
    518
    North Yorks
    Check the keep and make sure the metal piece is at a right angle, we had a similar problem
  6. Mart grump
    Mart grump Funster
    Apr 26, 2012
    68
    6
    Bathroom door
    Thanks for the information were having lots of teething problems just found out today reversing camera not working getting fed up no trust in dealer is this common with new motorhomes
  7. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    unfortunately this seems to be the way of many although there are a few that don't just take your money and run
  8. pappajohn
    Aug 26, 2007
    29,693
    17,303
    YO11 2BD
    New or used, there are good and bad dealers.
    some take your money then forget you ever existed....others, like our own peter (Johns Cross motorhomes), go out of their way to keep you happy.
    it's pot luck !
  9. sedge
    sedge Funster
    Jul 7, 2009
    4,516
    3,926
    Nr Jct 3 M6
    Our bathroom door does shut properly, but not if you don't shut it properly, IFYSWIM.
    So before moving off, we try and remember to give the 'shut' door a little shove, when it .... shuts! For some reason Pete finds it upsetting if all he can see in the rear view mirror is the bathroom door. :Laughing:
    You may also want to check your wardrobe door hinges - one of the screws in the bottom hinge of ours pulled completely out the other week - stupid far too short screws used. Mind, it's lasted nearly 3 years like that (and we are careful about everything, it certainly hadn't had a hard life even though it was well-used) but it's one of those things that had we known about, we'd have replaced em long before now. :Doh: Easily remedied.
  10. 993 s
    993 s Funster
    Jan 6, 2012
    4
    cheshire
    Ours did the same kontiki 649 . The timber /mdf in which the keep sits is not drilled out deep enough thus not allowing the latch to fully engage . Hope this helps . Now don't get me started on hartal hab doors ! GRR !
