Basic MH weight: includes driver, water and fuel ? (1 Viewer)
Ridgeway
3,653
6,145
Lausanne
NiBi Arto 85E
Since 2012
Just doing my maths on the load potential from our existing equipment list from our caravan and wanted to know what is considered within the basic weight of a MH i.e. empty weight. Is the driver included and is some fuel and water included ? I'm sure I've read some where that these items are although cannot be sure.
Sep 29, 2009
197
60
norwich
swift escape 640
since 2009
Swift allow just 75 kilo for driver plus around 90%of fuel gas and water within the mass in running weight
Reactions: SMB
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
It is supposed to be standardised but manufacturers have been known to calculate it differently. The correct term is Mass in Running Order (MIRO) although some refer to unladen weight (ULW). The latter is technically incorrect as it refers to the weight of the vehicle dry and with nothing in it. I have seen a reference to ULW in a Pilote brochure, but I think they meant MIRO.
MIRO should include: 75kg driver, 90% fuel, gas, fresh water and hookup cable if I remember correctly. Some makes allow for a full fuel tank. In considering a purchase, make sure you know what the specific manufacturer includes. Also note that MIRO isnormally stated for the standard model. If extras have been fitted, these will add to MIRO and reduce payload. Typical extras include: larger engine, auto gearbox, wind out awning, extra leisure battery, towbar, wind down steadies, sometimes cab aircon, sometimes internal concertina Remis blinds. You can see that it's a bit of a minefield. The only way to be certain of MIRO is to load it up with fuel, gas and water, then take it to a weighbridge.
Ridgeway
Ridgeway
3,653
6,145
Lausanne
NiBi Arto 85E
Since 2012
That sounds like a plan, the nearest WB is only 10mins away so that should be OK. See what you mean about extras, already been trying to add up the bike rack, wind out awning etc....
Will do a 100% fuel and water and 75kgs driver weigh test, only problem for that is that I'll have to go on a diet first.....
Apr 27, 2008
11,842
14,066
Eastbourne East Sussex
Hymer low profile
Since 1972
Most rubbish tips (sorry recycling centres) have a weighbridge and will usually let you use it for free if you don't want a printout. Weigh at least the total weight and if loaded at least one axle as well, you can work out the other by difference and though not exact is pretty good.
O
Old Soldier
Just been searching about MIRO or ULW (whatever it's called!). Any new thoughts for this old thread? It suggests " gas" but if you have space for 2 bottles does that include both? What about water in the hot tank of your water heater? Does it allow for grey water? ...( that that has not dribbled out of your partially open valve?! :think: ) Does it include fitted items like cookers, fridges etc? I realise that "add on's" that may not have been part of the original specification won't be included but what about those items that were included? Any he thoughts please? :happy:
Emmit
8,026
17,706
Cornwall
Pilote Explorateur
Jan.2014
It's been put on here somewhere else very recently.
Construction and Use Regs defines Unladen weight as;
"the weight of a vehicle or trailer inclusive of the body and all parts (the heavier being taken where alternative bodies or parts are used) which are necessary to or ordinarily used with the vehicle or trailer when working on a road, but exclusive of the weight of water, fuel or accumulators used for the purpose of the supply of power for the propulsion of the vehicle or, as the case may be, of any vehicle by which the trailer is drawn, and of loose tools and loose equipment."
In other words, no fuel, no gas, no driver.
Lenny HB
53,321
149,524
On the coast in West Sussex
Hymer B678 DL
With German vans they only include 20Lt of water and one 11kg aluminium gas bottle (approx 18kg).
John & Joan
1,425
774
Darlington
10 years this time
Some manufacturers are no longer counting water as part of the published unladen weight. They have a choice now of how much they include in the calculation. This way they can publish a higher payload figure in advertising. The need to keep below 3500kg MGVW and have a payload is driven by the B licence now available to newer drivers.
andy63
4,672
15,017
south shields
None
since 1990
My take on this is if you want to know your payload then it's the difference between MIRO and the GVW or maximum permissable weight... That's been covered above and manufacturers usually specify what they have included in MIRO..
It's Not the same as the vehicle unladen weight which is a term used in law to determine the vehicles max allowable speed ...and as has been covered many times is not a weight that is easily obtained...
Unladen weight. The unladen weight of any vehicle is the weight of thevehicle when it's not carrying any passengers, goods or other items. It includes the body and all parts normally used with the vehicle or trailer when it's used on a road.
But safe to say if your mass in running order comes in at less than 3050kg then your unladen weight is below that figure and the speed limits that apply to a car apply to the MH. .
Andy
Emmit
8,026
17,706
Cornwall
Pilote Explorateur
Jan.2014
With British CARAVANS they only include a 6Kgs bottle and I dont think they include water at all.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
You should get a weighbridge ticket from dealer before you buy it. If he plays funny go elsewhere. Buying an overweight unpracticale motorhome common:(
Lenny HB
53,321
149,524
Hymer B678 DL
Also need to take in account of the axle loadings, we can not make use of our full payload as the front of our van is light and rear axle has a limit of 2000kg. We uprated to 3850kg of the 350kg increase in reality we only gained an increase of 150kg as we were on the limit on the rear axle but the front is 200kg under.
Now on our second van and now would not consider any van with a payload of less than 750kg just not practical at any less and we travel fairly light.
JeanLuc
3,304
2,199
Warwickshire
On mine (2003 Star-Line) according to the Hymer spec. at the time, MIRO included gas (90%), diesel (90%), 75kg driver, EHU cable, and 70 litres of fresh water. But there was a proviso regarding fresh water that the full 120 litres could be included if the MAM allowed it.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
1994 and beyond...
That's a bit optimistic if lisence limited to 3500 Lenny. A 636 metre panel van never mind a coach built are heavier then some fully winterized double floor bigger compact A class.....
Lenny HB
53,321
149,524
Hymer B678 DL
All Hymer's nowdays quote a travel allowance of 20 Lt which they use for MIRO, if you look at the spec on a Hymer the water capacity is quoted like this, 120/20 Lt. It has been like this since at least 2008 also never seen a EHU cable included in the figures can't see why they would as they don't supply one.
Aug 18, 2011
12,130
17,992
derbys
AUTOSLEEPER SYMBOL
Simple,,load your van with everything you are taking with you,,everything,,go to weigh bridge with van with fuel water gas etc etc including the passengers that will be travelling and weigh it. First the whole van and then each axle. Then compare the weight on your ticket with gross weight and axle weights on plate on van. If all your weigh bridge weights are less than weights on the plate you should be legal. If not you need to throw some equipment out or all go on a diet,,,BUSBY:):)
Lenny HB
53,321
149,524
Hymer B678 DL
That's a bit optimistic if lisence limited to 3500 Lenny. A 636 metre panel van never mind a coach built are heavier then some fully winterized double floor compact A class.....
Only speaking from experience, my van had a MIRO of 580 kg I gave up trying to run it at 3500kg we don't even have an awning and that saves 45kg so we upgraded to 3850kg we are still on the limit on the rear axle.
It is possible to run an Exsis at 3500kg but not for us, we like to travel with a full water tank plus 2 x 20Lt of water in the garage, want to be self sufficient for at least 4 days and have our morning shower, we also carry a spare loo cassette that's a lot of sh*t to carry around.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
1994 and beyond...
Only speaking from experience, my van had a MIRO of 580 kg I gave up trying to run at 3500kg we don't even have an awning and that saves 45kg so we upgraded to 3850kg we still on the limit on the rear axle. It is possible to run an Exsis at 3500kg but not for us, we like to travel with a full water tank plus 2 x 20Lt of water in the garage, want to be self sufficient for at least 4 days we also carry a spare loo cassette that's a lot of sh*t to carry around.
Some of us restricted to 3500 so not an option Lenny, We have managed as a family of four for over 20 years:)
in a lightweight Euramobil etc..the reason you need bigger payload is you carry a lot of water ( full tanks +) as you mainly wild camp.we travel with 20 litres and fill when we arrive....
O
Old Soldier
That's what I have been doing for years Lenny, but since I started creating my "packing list" I'm trying to be a bit technical and load up according to the item weights. Thanks to all who are responding. ::bigsmile:
Lenny HB
53,321
149,524
Hymer B678 DL
Only a 120kg, keep looking at vans with 150/160 Lt water tanks I think on a Chic you can have a secondary tank taking it up to 250 Lt Oooo gets me all excited.:inlove:
Emmit
8,026
17,706
Cornwall
Pilote Explorateur
Jan.2014
Bit difficult to include water without a water tank, our German caravan had one.:)
There's a few now from the UK that have one.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
In a couple of weeks I hope to have a new Hymer ML-1 680 Which is Supposedly a 3500 van, but it is coming at 3860 or 4020kg, I will not have worry about the weight for at least 2 1/2 years until my 70th birhtday when I will be able to cut back to 3500 albeit with careful pruning and culling of contents, a trailer will then carry the load that is heavier. I seems stupid that the rules demand a cut back of the van weight bu not the maximum AUW If I become dangerous at that age then why the same AUW??? Just bloody bureaucrats having their little power play with the minions. I hope to have the van as soon as possible as Gertie has gone to a new family and I keep longing for the empty space to be filled again.
SMB
Apr 26, 2013
1,230
1,347
Spain
Coachbuild
Fulltiming since February 2013
I only have 25kg to go then I will be your average Swift driver (y)
