Basic Electrical question
Discussion in 'The Beginner' started by Nigel L, Apr 29, 2016.
  1. Nigel L
    Nigel L Funster
    Apr 25, 2016
    140
    168
    Soham, Cambs
    Hi, we are new to the MH scene, and are awaiting the delivery of our MH at any time now.
    The one thing that does confuse me are electrics.
    We intend to do a fair bit of wild camping, so have ask the dealer to install a second leisure battery, and may consider solar panels, depending on how we get on.
    After reading up on several threads, we keep comming accross the term Inverter.
    Please could someone please explain in very simple terms what an inverter is, and what they do.
    Many thanks.
    Nigel.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,112
    17,779
    YO11 2BD
    An inverter converts (inverts) 12vdc (battery) voltage to 230v (mains) so you can run mains operated equipment on a 12v system.
    There are many variables with inverters.
    They are power hungery, needing many times more amps than the appliance actually needs to work.
    Cable size depends on power needed but could be as big as 25mm sq.
    • Like it Like it x 1
    • Useful Useful x 1
  3. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,025
    13,891
    Bolsover, Derbyshire
    but it will also convert your 12V to useless in a few minutes (well maybe an hour)
    • Like it Like it x 3
  4. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,379
    5,636
    Guisborough
    If you are going the inverter route I would definitely go the solar panel option (as many as you can fit on).
    Martin
    • Like it Like it x 2
  5. Nigel L
    Nigel L Funster
    Apr 25, 2016
    140
    168
    Soham, Cambs
    Ok, thanks for the replies, so are you saying that in reality, that they aren't really feesable, as they will draw more power than you actually need to run the other appliance etc?
  6. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,025
    13,891
    there are definitely different ways to run things
    hair driers seem to be the sticking point though, amongst other things
  7. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,559
    2,565
    Trowbridge
    Some would say that, others would say you can't travel without one. It is up to what you need. We gave a small inverter and 200AH of leisure battery, no solar and we can manage a weekend without mains no problem.
    If you need longer, have less battery or want to run hairdryers or microwaves then your needs are different and you would need a big inverter and big batteries and some method of charging them etc.
    • Informative Informative x 1
  8. pappajohn
    Aug 26, 2007
    30,112
    17,779
    YO11 2BD
    The most important thing with inverters, you have to be able to quickly replace back into battery the amps used by the inverter.
    If an appliance uses 240watts per hour ro work your battery needs to be able to provide 20amps per hour....not a problem but......
    You now need to replace that 20amps each hour to keep your battery topped up.
    The more hours it isnt topped up means it gets flatter ad the inverter uses the battery reserve power, which in turn gets harder to replace in a given time.
    • Useful Useful x 2
  9. Old Soldier
    Old Soldier
    Apr 10, 2010
    902
    1,483
    Wells in Somerset
    Although we have a small inverter, in over 20 years motorhoming we have never used it! Use hookup when available, when not then use 12v and gas.... Have a solar panel to help top up battery and have a gas kettle for hot drinks. Use gas or BBQ to cook with and use a duel voltage cool box sparingly whilst running fridge on gas. Change light bulbs to LED and buy a couple of stand alone LED light units in case of emergency or if low lighting is required. Top up battery when driving out for the day. We have a duel voltage TV and satellite tuner and can manage at least 4 days of normal use of all systems on non hook up site or whilst wild camping. Good luck with your touring.
  10. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,164
    1,271
    Dronfield - Derbyshire
    I would not agree with either of those statement. A small amount more maybe.
    They use a small amount more because of the inverter losses. About 1A more
    Myself and many others on here wouldn't be without one, they give you so much more flexibility and 240 TV's ect are so much cheaper.
    I have had one on boats and campers for almost 20 years.
    I'm afraid many people are frightened to death about using too much battery power, I wont be governed by my battery's.
    I have 2 x 120A battery's and solar panels and never have a problem. Just don't expect to use any appliance with an heating element.
    I would guess that a 12V TV will take 5A, my 240V TV will be 6A.
    I turn my inverter on to watch TV in the evenings for often over 3 hours. The battery are always fully re-charge the next day.
  11. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,025
    13,891
    I am no expert, but you may be guilty of using numbers to support your own logic, bit like the calor gas / refillables suddenly calor is 50% more expensive
    My MH has a display showing Amps being drawn, probably not totally accurate, but our 12V LED TV's are around 2A each :)
    but you are definitely right on price (y)(y)
  12. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,185
    3,014
    Kendal, Cumbria
    The difference between mains TVs and 12v TVs in many cases is the supplied PSU. Remove it and suddenly you have a (reasonably priced) 12v TV.
  13. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,731
    3,378
    Cumbria
    We have a smallish inverter (600 w) that we use to charge the electric bike batteries, everything else runs on 12 volts or gas (y)
    • Useful Useful x 1
  14. Robin McHood
    Robin McHood Funster
    Mar 10, 2016
    249
    222
    Scottish Borders
    and nesspresso machines:LOL::LOL:
    @Nigel L several users have explained what the inverter does but don't be too put off them. They have their uses.
    You are better running things directly off battery power where you can, as others have stated.
    An inverter does lose some of your available battery power in the process of turning your battery DC power into AC power at 230v. Good top quality modern inverters such as the Victron Phoenix range can achieve efficiencies of 92% (you lose 8% of what you put into them, its not a fixed amp figure). However that efficiency level drops the more load is applied.
    So if you have something essential (usually to your better half) that only runs off 230vAC, which in my experience tend to be hair dryers (battery ones seem to be pretty rubbish) or Nesspresso machines :):) then bite the bullet and run them the minimum time possible, just don't leave them switched on!
    The other factor to think about is the type of equipment you want to run on AC. Some sensitive equipment won't run well (or possibly at all) on non-sine wave inverters, but pure sine wave inverters are more expensive.
    Add as much solar as you can fit and match them to as much battery capacity as you can to extend your off grid time as much as possible.
    Me too! and the other big inverter for that :swear::swear::swear::swear: Nesspresso machine :ROFLMAO::ROFLMAO::ROFLMAO:
  15. funflair
    Dec 11, 2013
    5,379
    5,636
    Guisborough
    If you want an inverter get one BUT understand what you can do with it, how much it will take out of your batteries and how you are going put to it back in.
    Whatever amps it says on the back of a microwave, coffee machine or hair dryer it will take about 20 times that in amps from your batteries via the inverter, for example 1200 watt coffee machine will be about 5 amps so take about 100 amps from your batteries, for an hour this would kill them BUT for two minutes is only 30th of an hour so less than 4 amps per hour so as long as you have solar or whatever to put this back "no problem".
    We have 320 watts of solar and can make between nothing and 20 amps charge, nothing would take forever to recover your depleted batteries but 20 amps will take next to no time.
    Understand your system and enjoy.
    Martin
    • Like it Like it x 5
    • Useful Useful x 3
  16. Cavs
    Cavs Funster
    Apr 10, 2010
    255
    249
    Bedfordshire
    :LOL::LOL::LOL: Yep, and coffee machines:)
  17. pappajohn
    Aug 26, 2007
    30,112
    17,779
    YO11 2BD
    Why would you disagree with my post ?
    If an appliance is rated 240watts it will consume, near enough, 1 amp @ 230v
    The same appliance will consume around 20 amps @ 12v...plus conversion losses.
    Ergo....power hungry needing many more amps to power the same appliance.
  18. etap
    etap
    Nov 19, 2014
    256
    233
    Somerset
    Hi NL.
    Not an answer to your original question but, each MH we buy always has a solar panel which will charge the engine and leisure battery, this is particularly useful in the winter when MH has little use, the batteries are always fully topped up, we only have a 100 amp leisure battery and we mostly use campsites with elect, hook up.
    If you are going to wild camp for a night at a time then you should be ok with an inverter as long as you are sensible about usage and have a solar panel, the problem comes when you wild camp for a few nights at a time, then you really need to be careful as to what you use, members here do wild camp often but they do have lots of battery power and probably only use the inverter for the tv (we don't have one).
    Good luck with your new MH.
  19. funflair
    Dec 11, 2013
    5,379
    5,636
    Guisborough
    Yes but they are different amps, the overall efficiency is only marginally lower.
    Martin
  20. Nigel L
    Nigel L Funster
    Apr 25, 2016
    140
    168
    Soham, Cambs
    Thanks for all the replies, they have been very useful, and even I understood them
    Basically, the items we would want to use, are as mostly mentioned above, ie, hairdryer for the goodlady Electric shaver, phone charge and I-pad charging.
    We will be getting solar panels fitted, so with two leisure batteries, and minimal use of an inverter for the items listed above, we should be ok?
