Bargain cab remote for X250 (1 Viewer)
Sep 22, 2013
200
199
Halifax
Relay self-build
Trainee MH owner
i would think it should as same vans apart from trim and engines did you get the right flahes when clearing and a steady light when cloning?
Yes, tried it a couple of times and it all went by the book. I note that it does say if it doesn't work first time, keep trying - so I may have another go with the fobs aligned differently. When I can summon up the interest...
Minxy
32,623
66,460
E Yorks
Carthago Compactline
You're stuck to paying Fiat prices if you want a second remote/key fob unfortunately ...:(
We got an extra one for our previous PVC and kept it when we sold the van as we were looking to get it re-programmed for the new one ... not a flaming chance!:mad:
Neckender
3,221
5,921
Neckend or North Wales.
VW T6.1Kombi day Van
Since 2004
My fob came today, our van is Peugeot X250 based and the fob does not work, I've tried several times got the right flashes, I've even tried it on our Nissan Micra and still won't work.
John.
Sep 22, 2013
200
199
Halifax
Relay self-build
Trainee MH owner
As you may have read above, I cannot get it to work on my Relay and it appears from this page that the Ducato may be different to the Boxer/Relay?
rolyk
42
11
South Glos
Warwick Duo
It works fine with my 2009 Peugeot. I tried to programme the bottom red button with the Van Bitz Strikeback remote but it wouldn't accept the code.
Incidentally, the original remote has a transponder chip embedded in the fob which is paired to a chip in the ignition key surround when the key is inserted. The spare key has the transponder embedded in the plastic part of the key. Without the correct transponder the engine won't start and it's this that makes an additional key so expensive.
lou020
489
360
huddersfield
autotrail chieftain
since 2010
i also bought one after reading this post. just programmed it and it works a treat. 2008 fiat ducato X250.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I bought one for the fiesta and it doesn't work, it is probably a rolling code on the Ford. BUT the second attempt wiped the genuine key and it wouldn't work after that until I reprogrammed it from the ECU details, it now works but the new fob is going to operate the garage door from now on.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
There are anomalies in the change between x250 x290 in vin numbers but as @Minxy Girl posted the visual difference is obvious
Mar 11, 2014
934
1,330
Lincs
PVC
Since 2010
Mines a 2010 fiat x250 and unfortunately it won't work. I get the right sequence of flashes but nothing activates. I've tried it with the remotes in different positions as suggested in the instructions but no difference. :(
Mar 11, 2014
934
1,330
Lincs
PVC
Since 2010
Having had no success on my 2010 van I nipped over the road to my neighbour and his 2007 van and had immediate success.
While they are both x250 the key fob is different.
Mine is quite oval like this
and my neighbours is more rectangular like this
Free-shipping-3-buttons-lock-unlock-and-hatch-release-remote-font-b-key-b-font-case.jpg
I'm not sure what year fiat changed the fob but it looks a bit like this is what determines whether it will work or not.
Nov 11, 2013
1,959
6,893
Tewkesbury
Hymer T-SL 668
March 2014
Nope, won't work on mine. Anyone want a free fob? Trouble is, the stamp will probably cost as much as the fob cost new! I will take it to the Malvern show and first one can have it.
zac
2,597
1,848
Basingstoke
Rapido A CLass 10000
since 2013
I have one someone can have if anyone at the retro festival next month :)
Minxy
32,623
66,460
E Yorks
Could I put first dibs on it please! :)
Minxy
32,623
66,460
E Yorks
Petest
199
185
Uk
New convert
Thanks for the tip @TheBig1 . Mine arrived today and works a treat with our 08 boxer.
Aug 19, 2013
2,950
4,273
Wells, Somerset
Elddis 115
since 2004
Oh drat, ordered one yesterday my van's a 2016. Sounds rather like it ain't going to work.
Oct 17, 2014
102
123
London
Possl Roadcruiser PVC
Since 2011
Just got one for my 2013 X250 - no good :(
Oh well.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Mine has responded to pairing as per instructions
Will know on Sunday if it works but looks promising (2008)
Thanks again @TheBig1
Techno
Jul 28, 2010
15,475
20,756
May 2010
Step-1 Clear the history code from duplicator
1. Press button A and B continuously until LED flash 3 times
2. Release button B (Keep pressing button A),and press button B Slowly for 3 times, LED flash
3. Release button A,finish code clearance.
If code clearance done properly, short press any button. Light won't flash at all.
If light flash when short press any button clearance process done wrong. Please repeat clearance process again.
Step-2 Copy code from original transmitter
Place the cloner remote and the original remote close together side by side. Make sure they are touching.
1. Simultaneously press a button on your original remote and one of the buttons on the clone remote and hold until the LED on the clone remote flashes steadily. The Blue LED will first flash 3 times quick, then stops for a second, then flashes steadily.
2. Release both buttons. Programming is successful. Copy other buttons in same way.
Even if everything done correct sometimes copying process failed. Repeat all programing process again and use different remotes position Face to face, back to back, like T Position.
Bailey58
8,798
29,336
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
Mine doesn't work on the van but it opens the back door on the neighbours house, I'll try it during the day when he's at work and his wife's home. (y)
Feb 15, 2014
711
1,246
cambridgeshire
Bessacar E450
3 years
yes my key is like that, have tried several times but no luck
