Banner Batteries - topping up (1 Viewer)
Jul 5, 2013
11,722
13,698
Since 2013
I havewa couple of 110Ah Banner batteries that need topping up. For the life of me I can't get the tops off! Tried all sorts of way to unscew them, but all I am doing is distorting the plastic. Is there a knack to it please?
Bluestar
279
164
Brighton
Class
10 years.. On and Off
Not stating the obvious but they are not the sealed for life type are they?
peterc10
Jul 5, 2013
11,722
13,698
Since 2013
I had similar problems when we got our van 3 years ago. Use a coin of appropriate size (I use a 20p) rather than a screwdriver.
@Terry gave me a tip and that is to use a pair of pliers to grip the coin rather than your fingers.
Graham, thank you so much. Spot on with both tips. A 20p coin plus pliers worked a treat. Thank goodness we had a 20p coin here in Portugal.
Big Lad
106
74
Tamworth
Lunar Roadstar 570E
When I top batteries up (and I have encountered your problem) the trick is, whatever your using to unscrew the caps, make sure it's thick enough to fit snuggly in the gap. We've probably all used a flat blade that's too thin and ended up chewing the head up. .. I found a large chunky flat blade that covers the width of the recess did the job for me, it helped that i applied a bit of downward pressure to avoid any slipping, but works well for me.
trevorf
57
90
Cheshire
C class
Since 2004
Banner sell a special tool to remove the caps but its about ÂŁ20. You can make one yourself quite easily. Go to your local hardware shop and buy a couple of "T" shape cabinet support brackets. The thickness is a perfect fit but they are slightly too wide. A couple of secs with a bench grinder (or couple of mins with a metal file) sorts them out. I found a slightly rusty one lying around my garage.
See photo.
