Badly Behaved Radio
Discussion in 'Tech/Mech General' started by Sueb, Apr 23, 2015.
  1. Sueb
    Sueb Read Only Funster
    Apr 23, 2015
    5
    Norfolk
    Hi - we are at our wits end - our Peugeot Boxer radio comes on at odd times and when it feels like it. Even when we are parked up with no key in the ignition! As it is kept in storage for weeks at a time without use, we have gone to use it and had a flat battery. Short of disconnecting the radio what can we do? Help would be appreciated!
  2. icantremember
    icantremember Funster
    Sep 2, 2010
    5,214
    7,334
    Nr Watton in Norfolk
    Hi Sueb and welcome from another Narfooook resident.
    Your radio will normally use a small amount of power when turned off to keep it's code and any clock, as will any alarm fitted to your m/h.
  3. Clickem
    Clickem Funster
    May 20, 2014
    220
    146
    Northumberland
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,322
    YO11 2BD
    Says it all....
    With ign off there are still parasitic loads on the battery which could see it flat within 2 to 3 weeks or less.
    Best solution is disconnect the engine battery when in storage.
    It will still go flat due to self discharge, all batteries do, but could take many months.
  5. Sueb
    Apr 23, 2015
    5
    Norfolk
    Thanks for that advice which may cure the problem. Wonder why its happening though? Got a gremlin in it!!
  6. pappajohn
    Aug 26, 2007
    29,703
    17,322
    YO11 2BD
    Forgot about the radio.
    Sounds like it has a fault causing it to turn itself on.
    But that isn't the only cause of the flat battery.
  7. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,694
    11,831
    Plympton, Devon
    At the risk of stating the obvious it sounds like the radio is faulty. But perhaps a poor connection somewhere is giving it an intermittent power supply, and when comes on the radio also comes on - like my phone lighting up when I plug it in to charge.
  8. Bluestar
    Bluestar Funster
    Nov 3, 2014
    274
    166
    Brighton
    I had a problem with my radio, what year is your motorhome?
    As said could be faulty radio or under the dash in front of the driver, there is a plug and socket that takes the loom through to the engine bay, I had corrosion on this plug and socket causing an intermittent radio and interior light.
  9. Tootles
    Tootles Funster
    Sep 14, 2013
    9,117
    32,059
    Lancaster
    Mine was the same. At last, I found it was fitted with a timed alarm system, which you can disable. (y)
  10. Sueb
    Apr 23, 2015
    5
    Norfolk
    Thank you for all your help - will investigate further today!
  11. scotjimland
    Jul 25, 2007
    28,934
    25,589
    shot in the dark.. probably wrong..
    but does it have RDS / EON set for traffic alerts and that is turning it on ?
  12. Sueb
    Apr 23, 2015
    5
    Norfolk
    Yes it does have the RDS/EON setting - I did wonder this, but the radio keeps on - if it was the RDS it should shut off after the travel report.
  13. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,801
    1,025
    Cark, Cumbria
    A friend of mine has the same problem with his Ducato based van
    He now takes the radio face off when parked up, no flat battery now
  14. Sueb
    Apr 23, 2015
    5
    Norfolk
    The more I read the more I see the same problem with different motorhomes. What a pain!
