Bad news or am I over- reacting
Discussion in 'Motorhome Chat' started by combi, May 29, 2011.
  1. combi
    combi Read Only Funster
    Aug 23, 2010
    64
    9
    Just decided to refix a bit of loose trim on the MH, a small aluminium strip covering the join between the main body and the fibreglass skirt.
    Big Mistake as ignorance is bliss
    The part of the floor that this strip screws into is rotten I would guess that at some time in the past either the water tank or the water heater has leaked causing this damage. If I press the floor in this area from inside the van it feels spongy.
    My reason for the post is to ask is this something that can be easily repaired or should I be prepared for major expense.
    If a repair is possible does anybody know of a good repair workshop near Colchester.
    Looking forward to hearing replies that will put my mind at rest.
    A depressed cakeboy:Sad:
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    Any floor repair can be expencive. 1st make sure any leak has actually been cured. Next decided are you doing it or chopping an arm and leg off to pay for it to be done. A small area that you are not walking on could possibly be injected with a preparation to harden it all up. Otherwise it almost certainly involves removing furniture and fitting to gain acess for replacement. Good luck let us know how you get on.
  3. hilldweller
    Dec 5, 2008
    27,274
    26,271
    Macclesfield
    I've seen that posted several times, all Swift and done under warranty.
    Are you that lucky ?
  4. combi
    Aug 23, 2010
    64
    9
    Never that lucky
    Its a Herald Squire 1998
    Thanks for the interest
    cakeboy
  5. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,359
    5,374
    East Sussex 01-580-881288
    If its not too extensive you can get some goo that you inject into the floor which makes it solid.
    Apollo A8136 Floor delamination adhesive kit
    Peter
  6. combi
    Aug 23, 2010
    64
    9
    Thanks for the reply but after pesearching on the net I think it is too bad for this product.
    Thanks again for your interest.
    cakeboy
  7. Autoquest
    Autoquest Read Only Funster
    Oct 13, 2008
    391
    36
    Small EU backwater
    I'd be tempted to go for a total DIY refurb
  8. Wildman
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    Without wishing to add to your problems, not only the floor but the sidewall timbers will also be affected.
  9. combi
    Aug 23, 2010
    64
    9
    Further investigation shows that the damp was caused by the pump wire hole letting water out when the tank was filled to the top. Is this normal .
    Has anyone tried this stuff or am is this just my wishful thinking. www.linesofpinner.co.uk/r-repair.php?productID=PCP12
    Still living in hope that this will not be a really expensive.
    cakeboy
  10. Wildman
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    if its just a small area should work fine, however make sure you seal the tank to prevent further spillage.
  11. Terry
    Terry Funster
    Dec 27, 2007
    10,758
    6,253
    South yorks
    Hi CB,firstly you have nothing to loose by trying the injection method.(maybe £100)If you have to go down the new floor route then if you are handy you may as well do a total refurbish and as such around £2,000 to £3,000 :Eek!:If you are not handy then at least double :Eeek::Eeek:That would put you in the realms of how much is the van worth ?
    Inject it and get rid? or everything out replace floor fit it all back together and keep it ?or total refurbish knowing it is good for a lot of years to come?
    terry
  12. hilldweller
    Dec 5, 2008
    27,274
    26,271
    Macclesfield
    Are you sure ? Unless it's one big hole and it's been over filled every time then it feels wrong to me that dribbles would cause this. It's more likely long term regular ingress from somewhere - even the tank leaking at a joint.
  13. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,842
    3,341
    Eastbourne East Sussex
    I used a similar substance on a trailer caravan many years ago. It was quite effective for a cheap repair, but make sure you've found the source of the leak first.:thumb:
  14. sandied
    sandied Read Only Funster
    Sep 21, 2010
    18
    4
    Essex
    Repair Workshop
    Hello
    We live in Marks Tey. We use a secure storage unit at Marks Tey where there is also a motorhome/caravan workshop, SH Caravans, 01206 213181. When we first purchased our van we weren't too sure if all the 'out-of-sight' things worked.
    I had what is called a Habitation Service which checks all electrics, water system, gas system everything apart from the engine. With VAT it cost £185 but was worth it to know all was in order. They do all repairs except engine repairs and the labour charge is £45. There is another workshop I have used also with good results and the labour charge there is £40 but it is in Great Bentley, 01255 823333.
    Hope this helps.
    Eddy
  15. Rayb182
    Rayb182 Funster Life Member
    Nov 13, 2009
    1,486
    1,616
    Great Bentley
    Bentley Liesure Services,
    Dines Farm
    Great Bentley
    CO7 8RF
    Tony (Lopez) will give a fair and honest quote, we use him every time.:thumb:
    http://www.bentleyleisureservices.com/
