bad erths on the van (1 Viewer)
Nov 18, 2011
11,862
42,968
Planet Earth
A van
Over 25 year's
had a few problem with the electrics on the van think I have fund the problem the earth tags are corroded
thanks @Jaws john for the advice myself and the grandson will be looking at it tomorrow
bill
Nov 6, 2013
3,201
229,388
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
Good luck Bill. Earth faults are sometimes difficult to find but I'm sure with the help of the wee man you will have no problem (y)(y)
Wildbill
Nov 18, 2011
11,862
42,968
Planet Earth
A van
Over 25 year's
I have three of them fighting for my attention so tomorrow I will play a gam spot the black wire attached to the body of the van the one that finds the most gets a prize
DBK
18,022
48,089
Plympton, Devon
PVC, Murvi Morocco
Yes, good luck, devil's to find. Jiggling connections might help.
Wildbill
Nov 18, 2011
11,862
42,968
Planet Earth
A van
Over 25 year's
Ok fited all the new erths to the van cleaned up all the earth tags replaced all the corroded spade fittings.
now have window wipers side lights front and back and indicators hazard lights but no head lights or tale lights had tester on fuse box no power gowing to fuse no 3/4/5/6 there the ones the work the lights switch dead as a do do no power doing to it was thinking relay
DBK
18,022
48,089
Plympton, Devon
PVC, Murvi Morocco
You've had a busy day Bill! Going in the right direction though. You will get it sorted, nothings sets you back for long.
Wildbill
Nov 18, 2011
11,862
42,968
Planet Earth
A van
Over 25 year's
Fund the fault thanks to @Jaws looks like a connection had come adrift on the fuse box apparently it's a common fault with the older MK1 Ducato .
Will have to do a bit of crawling around under the dash board tomorrow
bill
Wildbill
Nov 18, 2011
11,862
42,968
Planet Earth
A van
Over 25 year's
ok finally got the lights working the live feed from ignition was not working new ignitions switch needed at sum Pont had to bit the bullet and get a auto electrician to help me but every thing working now.
lesson learnt there
bill
