back to fitting fridge
Discussion in 'The Beginner' started by Bruce, Feb 14, 2013.
  1. Bruce
    Bruce Funster
    Aug 12, 2012
    142
    50
    Glasgow
    Hi I Have just bought an old electrolux fridge from an old caravan it is a 212A 3 way I have been assured that it is in full working order and have tested it in the house on 240v.and it works fine
    I will maybe only use 240v and 12 v for now . Could anybody explain how I can install this as I have kitchen unit at the back of my transit near rear doors, and not against a sidewall. In simple terms how can I install or have I bought something unsuitable I.E venting etc. Lots of advice in simple terms needed please.............Bruce
  2. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,761
    39,079
    Just nail/fix it to the floor where you want...
    If possible put a vent in the back if it is being incased...
    "DONT" even contemplate fixing a gas pipe to it and running it on gas, "Without" it being fully vented... :Blush:
    Not a lot of heat comes off 240V or 12v... But remember on 12v what ever battery`s you have it will be a huge drain on them.. :Sad:
    So would have to be EHU where ever you camped.. :thumb:
  3. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    Hi Bruce no problem at all if using only 240v and 12v :thumb:240 v is just a simple wiring job and on 12v side you really need to wire it through a relay from the alternator so that it only works while engine is running and it does not flatten your battery :thumb:It's normal to fit a twin relay so that the fridge and the leisure battery both get power/charge while engine is running :thumb:
    Do not even try to use gas unless it is properly vented via an outside wall and sealed with drop vents :Wink: :Eeek::BigGrin:
    Terry
  4. old-mo
    Oct 16, 2008
    12,761
    39,079
    Thats what I said.... :Tongue1::Doh::Rofl1:
    But I worded it "Better"... :thumb:
  5. gillnphil
    gillnphil Funster
    Apr 12, 2010
    905
    3,606
    West Suffolk
    fridge fix
    If you need to see if the internal light is working, just drill a hole in the door !
    Good luck
  6. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    Yes Mo that's exactly what you said and exactly what I typed Acknowledging and agreeing with you first time around :thumb: BUT thenn I was on the tablet and caught a button so it vanished :Doh: so did another shorter version :Eeek::BigGrin:
    terry
    BTW you can usuallytell when I am on tablet -not as mant spelling mistooks and my end sig istarts with a capitol T :Rofl1::BigGrin:
    • Like Like x 1
  7. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    when it comes to venting ( if you really want to ) a vent in the floor under the rear of the fridge is ok for a lower vent and doubles as a gas drop out.
    for the upper vent you can use ducting to get to the side of the van although the gas exhaust will have to follow its angle to the side of the van so could be quite high (not a problem if there is a cupboard above the fridge) or i thought i saw somewhere they do a roof exit for a fridge (could be mistaken on that one but worth a google)
  8. scotjimland
    Jul 25, 2007
    28,934
    25,589
    Irrespective of using LPG, 230v or 12v an absorption fridge requires venting.. this is not to get rid of fumes but to enable a flow of air over the heat exchanger to remove heat .. If you seal it into a cabinet it won't work.
    If only using 230 or 12v it could be vented to the inside of the van but this won't be very efficient and in summer it will certainly overheat and stop cooling.
    As mentioned the bottom vent could be in the floor .. and the top one on the back door which would incorporate the flue gas vent..
    The fridge should be sealed into a cabinet in such a manner that in the event of a fault, LPG or combustion fumes, ie Carbon Monoxide (the silent killer ) cannot enter the living area.
  9. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    In one of my vans the fridge was simply wired to 240 and 12v NO gas and no vents :thumb: it worked fine :Smile:plus it heated the wardrobe above it which came in handy as a drying place :BigGrin:
    It was only after I connected gas that I needed the fridge sealed and both drop, and rear vents :Smile:
    Sometimes things just work O.K. even though logic says different :BigGrin:
    Terry
