B564 - cracked shower tray (1 Viewer)
May 22, 2016
77
22
Surrey
Adria Matrix 600DT
Since 2012
Help....
the shower tray in our Hymer B564 broke at the weekend and I need to repair or replace asap. The plastic had become brittle and broke around the water-drain/plug-hole fitting.
Can anyone suggest a supplier and how easy are these to replace? I'm an experienced DIY'er but any advice will make the job easier.
Many thanks :)
Forestboy
5,023
8,338
Forest of Dean
A Class Hymer B694 tag
Just had mine replaced by Hambiltons after 3 repairs none of which were very successful, should have replaced first-time. Once they get to a certain age repairs are a lottery as the plastic gets very brittle.
Depending on the year and if you're going to keep the van new is better but spares for older vans are starting to become hard to get. Ours is 2002 and some spares are now discontinued we actually fitted a completely new bathroom but some panels including shower door were no longer available. We also fitted new blinds and had the same problem.
Suppose the other factor is how much you use your van with us its approx 6 months a year so the bathroom gets a hard time.
Have to say a very expensive job but we're over the moon with it the bathroom looks brand new now.:)(y)
Mar 16, 2010
3,050
29,977
Carmarthenshire
In between
Since 1988
If you need a replacement making Derek Justice in Derby does an excellent job....he made a replacement washbasin for our Hymer made TEC freetec and we have been very pleased with the quality ..it is a lot stronger than the original. I can let you have his details if you want them.
wanderer
643
769
huntingdon
a class Arto
since 2008
We had ours done by Speedcoat 2 years ago and all has been fine since . If its a quick repair you want maybe its the way to go . They operate on an area franchise basis and did mine on my drive in a day
Microchip
138
126
Hampshire
Low Profile
We also used Speed cote, very good finish and much stronger than original
Keith..
