B2B
Discussion in 'Motorhome Chat' started by DavidG58, Aug 28, 2014.
  1. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,830
    13,568
    Bolsover, Derbyshire
    Jim posted a link to one these today
    http://www.sterling-power.com/products-battbatt.htm
    I have been thinking about similar already, but reading the instructions wonder just how easy it is to fit yourself
    then remembered I have tried twice to find my engine battery and failed both times
    do you think I maybe lack the necessary??
    seriously though, if it so easy would it be fair to think I wont be charged too much to have one fitted?
    That would be my preference, is this the sort of thing that people do at shows? we are going to Lincoln
  2. Pat4Neil
    Pat4Neil Read Only Funster
    Sep 28, 2008
    1,377
    487
    Essex
    Eddie van bitz might fit it if tge arest tge show, or roadpro, dont know if david newell does that type of thing, if you dont know where your battery is, i would recommend you get it fitted.
    • Like Like x 1
  3. grasscutter
    grasscutter Funster Life Member
    Oct 11, 2009
    1,370
    2,284
    East Wittering. West Sussex.
    Failing that how about buying the B2B and then getting a couple of crates of alcohol and inviting all the funsters to help fitting it.:rofl:
    • Like Like x 1
  4. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,830
    13,568
    Deal, are you going? (y)
    No beer before fitting though, unless only watching :D
    • Like Like x 1
  5. lugnutt
    lugnutt Funster Life Member
    Sep 9, 2007
    1,183
    455
    wednesbury.westmidlands
    i wont one two a beer and a b2b could make it a party
  6. Steve
    Steve Funster Life Member
    May 8, 2013
    1,571
    1,850
    Compton Berkshire
    great piece of kit(y)
    but to fit properly, let someone who can garrantee the work. there are some censer wires that need to be connected and the right size cables
    • Like Like x 1
  7. gwyntaxi
    gwyntaxi Funster
    Jun 9, 2009
    170
    63
    waunarlwydd,swansea
    If you can't find your battery I would leave it to some one who can,it's not a difficult job but if you have any doubts about your ability to do the job,I'd leave it to the experts for the sake of £30-£40 its not worth watch
    -ing your pride and joy go up in flames through mis-wiring,Dave Newell sounds like a good bet,seems a gen
    -uine enough guy.
    • Like Like x 1
  8. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,830
    13,568
    I will be getting it done, looking for fitter local to East Mids / Yorkshire though
    Will see what we find at Lincoln Show, there is a local firm Auto Mate who may be there, I have used them before
    (y)
  9. TerryL
    TerryL Funster
    Mar 5, 2010
    1,404
    1,386
    North East
    Any good auto-electrician should be able to do the job in well under an hour. They are really quite simple although you do have to get it right and, if as others say, you have any doubts about your ability it's money well spent.
    Well pleased with ours.
    • Like Like x 1
  10. TheCaller
    TheCaller Funster
    Sep 23, 2013
    1,932
    2,296
    Lincs
    Are you sure you need one? Have a hunt through the M/H documentation to see what make of 12V control system you have. I would expect your van to have something that is already going some way towards doing what a B2B unit would do.
    If you have a Schaudt Electroblock fitted already, then it's unlikely you will get the expected benefit.
    Any UK conversion more than 5 years old (& quite a few new ones) will almost certainly benefit. I'm not sure yours would fit that category. I recognise your van as yours when I see it, but I can't remember the make, model & year.
  11. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,830
    13,568
    Thanks Simon
    Ours is an 09 spec Hymer 800S, with the Schaudt system
    I often wonder why some of the questions that come up relating to charging do, ours seems to do things differently
    we have Hab and Cab simultaneous charging from mains hook up and our solar panel charges Cab when Hab 80% full (I am guessing a bit on the 80% bit, but I do know it changes over at some point)
    One of my biggest concerns is that we have a permanently live 12V cigar type outlet in the cab, connected to the cab battery, I have flattened the cab battery once with over use off hook up, don't want to do it again
    Is a B2B not the right answer?
  12. Wissel
    Wissel Read Only Funster
    Sep 16, 2013
    301
    323
    Cornwall
    Might also be worth looking at the CTEK D250s Dual.
    You can connect your solar panels to this as well and it will charge your leisure batteries and engine battery.
  13. gibbon
    gibbon Read Only Funster
    Feb 25, 2013
    308
    326
    Shatterford
    We have the above, fitted by Dave Newell. Works a treat & very happy with it. Off grid, no problem(y)
    • Like Like x 1
  14. Wissel
    Sep 16, 2013
    301
    323
    Cornwall
    It's a great unit. I have one as well coupled with the CTEK Smartpass so it charges at up to 100a per hour but I have 400a of batteries.
    • Like Like x 1
  15. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,830
    13,568
    I remain as grateful as ever for helpful input, but no less confused
    I hope to get some technical help while at Lincoln next month
    Funsters and or Fitters (y)
  16. Wissel
    Sep 16, 2013
    301
    323
    Cornwall
    Just had a look at the exhibitor list and Dave Newell will be there. Very knowledgeable guy with a good rep.
    • Like Like x 1
  17. sally47
    sally47 Funster
    Apr 29, 2014
    173
    64
    Not quite sure what we are talking about here as totally stupid with electrics but I assume to do with engine battery going flat really helps with solar panel but my battery use to go flat after two or three weeks bought a battery mate off jim via van bits brilliant can't recommend it enough even installed it myself
    • Like Like x 1
  18. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,830
    13,568
    These kind of comments scare the life out of me :D
    But bless your enthusiasm, but please never let buy a used MH from you :whistle:
    Good luck to you though, I think we are talking about the same thing by the way (y)
  19. Wissel
    Sep 16, 2013
    301
    323
    Cornwall
    I didn't have much of an idea on electrics when I first started my build and was getting so much conflicting advice I had to spend months learning all of the issues with 12v charging (it's often referred to as a black art).
    I wrote an article on my findings here that may help:
    http://myselfbuildcamper.co.uk/new-12v-electrics-total-charging-solution/
    and also a brief video I made on how the system works:
    http://myselfbuildcamper.co.uk/ctek-d250s-dual-smartpass-review-video/
    12v electrics were the single most important part of my build as I work on-line and needed a PC running in my van (meaning I can work from the beach). After a few attempts at systems that didn't cost much I gave up and opted for a money no object, what's the best system available, approach.
    This is what I came up with and it's great a year on. Once connected everything is automatic and I never need to even flick a switch. It just works flawlessly.
    Hope this helps.
  20. TheCaller
    TheCaller Funster
    Sep 23, 2013
    1,932
    2,296
    Lincs
    No, I don't think it is. The unit you link to is designed to make best use of the alternator while the engine is running. Your Schaudt will do that, albeit not quite as aggressively as the Sterling.
    Your need is to keep your engine battery topped up while the engine is off, so no alternator output. The Schault is supposed to do that too, but it will only do that while it is getting sufficient charge into it to keep the habitation battery charged & some left over. If there isn't enough coming in from your solar panel to keep up with what you are using from the habitation battery, then there won't be anything available to top up the engine battery.
    If you didn't have the Schaudt, I would suggest a Battery Master; made & supplied by VanBitz & also available from Jim's shop. Every time the engine battery drops more than half a volt below the habitation battery, the Battery Master will use the habitation battery to charge the engine battery at 1.1 amp. Not a lot, but designed to replace the power used by clocks, radios & alarm systems. The problem is that with the Schaudt trying to do the same job, they are inclined to interfere with each other.
    I suspect the best solution is the simple one - either don't use that particular 12V socket when parked up, or get it rewired so it draws it's power from the habitation battery. Rewiring it is, in theory, a very straightforward job. The practical difficulty is threading the wires! It may be cheaper to just fit another 12V socket somewhere convenient in the van drawing it's power from the habitation battery. I didn't have any 12V sockets in my van apart from two on the dashboard which were both fed from the engine battery & only worked with the engine running. So I got Dave Newell to fit another socket in the living part of the van, fed from the habitation batteries, while he was doing some other work on it.
    Whether Dave, or any other installer, would do that at Lincoln will probably depend on how well they know your model of van. The time taken to do it will depend entirely on how easy it is to run the cable from either the battery or from the Schaudt (better) to where you want it positioned. If they know the van they will know how much time to allow.
    • Like Like x 1
