- Jul 28, 2010
- 15,475
- 20,756
- Rapido 7090F 3 litre 160
- May 2010
Trouble with Dometic is they use their customers as guinea pigs
I do have an add blocker installed and therefore cannot see your link. However, you can, so will know the type of batteries you have. May I be so bold as to advise you get some solar power installed so your batteries are charged when your motorhome is static (assuming it receives sunshine). Otherwise, your just guessing about the battery condition. They should be fully charged when not being used.@PhilandMena Thanks for clearing that up for me about the charging,, as my sterling b2b charger runs everytime the MH is started , so my batteries could be at 95% or 50% , it just depends on how much i have used them for between journeys.
As for the type of batteries i have , i linked my batteries below your excellent post on page 1 about the 3 stages of charging
but here they are again
Amazon product ASIN B01DT5GA7Ep.s if you are using an add blocker , then it will be blocking the link for my batteries
Well these guy's seem to know how batteries work. (It's also in the resources section).What did we do before multi-stage chargers???
Too much technology and not enough understanding of how batteries work.
Peter
Only £1,500 each we are taking 100 but don't expect to sell them allCome on Eddie give us a clue - how much?????
Sadly like all multi nationalsTrouble with Dometic is they use their customers as guinea pigs
I did rate your post as funny problem is it true.Trouble with Dometic is they use their customers as guinea pigs
My fridge works ................................... now no thanks to them.I did rate your post as funny problem is it true.
One day, maybe one day they will make a fridge that works, I'll probably be pushing up the daisys by then.
I can buy 19 x 125ah batteries for that so even if I threw one away every year I'd get 19 yrs useOnly £1,500 each we are taking 100 but don't expect to sell them all
Solar panels will be fitted down the line , as that will complete the system as far as i'm concernedMay I be so bold as to advise you get some solar power installed .
