B-B-Q point
Discussion in 'Tech/Mech General' started by Sundowners, Mar 11, 2013.
  1. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,373
    1,458
    Suffolk
    We are looking at fitting an external b-b-q point on the camper-----I am looking at using the old (now unused) gas supply to the genny------if I fit the new point onto this pipe will I be able to fit an external bottle to supply the system, as well as run accessories, like b-b-q ???------will the gas flow both ways ???--------------can the point be fitted inside a locker ??
    Nigel & Pamala
    • Like it Like it x 1
  2. knokinonabit
    knokinonabit Funster
    Dec 28, 2011
    2,483
    2,453
    Stokesley, North Yorks
    I would say that gas is like water, it can flow in any given direction, unless there is something to stop it. ie a tap.
    So if there is pressure pushing it along it should go anywhere it can.
    Recently I asked about having an extra pigtail fitted in the gas locker so that in a dire emergency I could connect a spare gas bottle (in case I could not find a garage to top up onboard refillables), as I have a spare 6kg Calor bottle.
    The answer was to fit the gas bottle with a regulator and b-b-q plug in and feed the gas in through the b-b-q point, as the gas will go both ways.
    I'm sure someone will tell me how dangerous this is, but I am open to all advice on here, as it's the best advice I've ever had. :thumb:
  3. Sundowners
    Oct 30, 2007
    2,373
    1,458
    Suffolk
    That is exactly what we are after-----we carry Camping Gaz bottle (for B-B-Q) And although these are VERY expensive to exchange, they are available just about everywhere, so could get us out of a fix:Smile:-------and if we stay where a local bottle is practical we have that option:thumb:
    Nigel & Pamala
  4. Sidney
    Sidney Funster
    Jan 27, 2013
    1,286
    835
    Stamford
    I fitted (but never got to use) a bullfinch gas barbecue point.
    It's rather like a ball valve. Insert the gas pipe and turn and the gas flows either way.
    A neat solution really and I can't see anything wrong with it as long as you have a regulator on the gas bottle.
    Do ensure that a thorough check for leaks is undertaken - be Gas Safe :thumb:
  5. FULL TIMER
    FULL TIMER Read Only Funster
    May 31, 2012
    796
    712
    NORWICH
    These bbq outlets are just that , outlets and perfectly safe to use for it's designed use, however they should not be used as an inlet, yes it would work but you can no longer isolate each appliance inside, not sure of the effects it would have if you also had the normally used bottle turned on and obviously it would be hazardous if you had no bottle connected as you would be relying on a single tap to stop your vehicle filling with gas, They are designed as outlets and should only be used as such and I think most carry warnings saying this either on the outlet or in the fitting instructions
  6. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    What you are looking for is commonly described as an extend-a-stay. We have one fitted in the supply to hab beyond the fixed tank valve. With fixed tank turned on its a BBQ point, with fixed tank switched off and a spare bottle (with its own regulator) can be fitted to supply the habitation requirements. So best of both worlds. I have room for 2 x 11kg bottles as well as the fixed gas tank.
  7. Sundowners
    Oct 30, 2007
    2,373
    1,458
    Suffolk
    thanks for the info------that's given me something to think about:Smile:
    Nigel & Pamala
  8. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,421
    5,449
    East Sussex 01-580-881288
  9. Ash
    Ash Trader - Service & Repairs Life Member
    Sep 22, 2007
    770
    195
    The Midlands ( Nuneaton )
    shame you not at newark i could have fitted you one there:thumb:
  10. FULL TIMER
    May 31, 2012
    796
    712
    NORWICH
    Maybe one of the two traders could clear up the matter on whether it is safe or possible to use these bbq points as an alternative gas inlet, I was pretty sure that the advice I gave earlier on in the thread was correct but always glad of either conformation or correction by those in the know.
  11. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    a couple of years ago at one of the shows i watched someone having a gaslow system fitted on site.
    I could be mistaken but it could have been Mark at CLS doing the fitting.
    as the gaslow bottles are supplied empty the van owner needed a temporary gas supply until a gas fill was possible.
    simple...the removed 'non fillable' bottle was fitted with a regulator and connected to the bullfinch BBQ outlet with the gaslow bottles turned off.
    there is no difference feeding gas in to the van this way to using a calor bottle, except you have one more joint in the system....the bullfinch connector.
  12. pappajohn
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    why could the individual appliances not be isolated ?
    the BBQ outlet would usually be connected between the inlet regulator and the inboard gas manifold so you still supply the manifold in the same way.
    even if fitted after the manifold it would be common with just one appliances pipe and the others could still be isolated individually at the manifold or indeed be turned off altogether by isolating the common appliances manifold valve.
    of course, the common appliance would still be live though.
    basically it does the same job as a proper extend-a-stay connection.
  13. FULL TIMER
    May 31, 2012
    796
    712
    NORWICH
    This is in the instructions for the Truma bbq point;
    Operating instructions
    When external gas equipment is being connected, the operating pressure of the gas supply of 30 or 50 mbar must correspond with the operating pressure of the equipment that is being connected (see data plate).
    The plug-in connection can only be made if the quick-acting valve is closed. The safety locking mechanism can be released by sliding back the coupling sleeve.
    The coupling K-valve is designed such that the quick-acting valve can only be opened if the connection is being made via the plug-in connection. The connection is made by inserting the plug-in connection into the safety coupling.
    This operation can be carried out using one hand. After un- coupling the equipment, seal off the valve opening using the protection cap.
    The external gas socket is only suitable for removing gas, not for feeding gas into the gas system.
    As quite a large supplier of gas products I would assume they have a valid reason for the warning they give in their instructions. I have only ever fitted their version so not sure about others, I'am sure if it did the job of a proper extend a stay then Truma wouldn't miss the chance of marketing it as such
  14. knokinonabit
    Dec 28, 2011
    2,483
    2,453
    They haven't mentioned fitting a gas bottle with a regulator, so possibly they are covering themselves if someone tries it without one. If you did connect without a regulator I would imagine there would be one hell of a whoosh when you turned the bottle on. :Eeek:
  15. Ash
    Sep 22, 2007
    770
    195
    Come and see me at Newark show for advice if needed we have a stall there :thumb:
    Ash
  16. pappajohn
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    For one reason and one reason alone.......if the valve stub is pulled out, either intentionally, maliciously or by accident, there is no way to stop gas escaping from the open hose connected to the bottle, other than turning off the bottle.
    once connected it is just as safe as connecting the regulator to a bottle.
    if used for its intended purpose, if the stub is pulled the safety valve is automatically closed and no gas can escape from the system
  17. FULL TIMER
    May 31, 2012
    796
    712
    NORWICH
    I see your point, but I'm sure an insurance company would rub their hands with glee if anything did go wrong and they came across a bottle connected as such to what should be an outlet, I definitely would not advise any of our customers to use the bbq outlet for anything other than it's intended purpose.
  18. Sidney
    Sidney Funster
    Jan 27, 2013
    1,286
    835
    Stamford
    Yup no sense flogging this horse
  19. grasscutter
    grasscutter Funster Life Member
    Oct 11, 2009
    1,384
    2,312
    East Wittering. West Sussex.
    Just have a walk around any Spanish site and see the amount of vans feeding in gas through the BBQ point.
