Awnings (1 Viewer)
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Don't put out when windy is a good rule. You can get tie down straps bit if you expect wind... then wind it in.
Rain is not a problem
D
Deleted member 29692
Also remember to always have one end lower than the other at the front, especially if rain is likely. This will let the rain run off. If you have the legs set at the same height rain will collect and pool in the middle of the canopy, it will sink in the middle and you won't be able to open your hab door.
Common newbie error. We've all done it. (y)
The other thing that you will almost certainly do is stand outside the canopy, right in the path of the torrent when you lower one of the legs to let the collected water run off. :D
11,950
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I always use tie-downs (and peg the legs) even if there's no sign of wind at the time. If it starts to get windy I wind it in only when the noise becomes too annoying. For me the noise annoyance wins long before the wind is enough to cause damage.
