Awnings and truma heater / fridge vents (2 Viewers)
Nigel&Debbie
322
212
Full Timer
Autotrail Dakota
since Jan 2013
Looking at getting awning / safari room for motorhome.
Question - The truma heater vent and the fridge vents are on the same side as the hab door and will be inside the awning. Do I need to worry about the carbon monoxide produced when running everything on gas? Is there sufficent ventilation due the design of the awnings?
|Nigel
Jan 24, 2010
2,440
4,848
Adria Twin
Weve got the same 'problem'
Having been in front of the heater vent when its in full flow on a few occasions...I concluded it wouldnt be a good idea!!!
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
There are enough gaps round the safari room or awning to blow any fumes away, so not a problem. What size safari foom are you looking for? We have decided to sell our 3.5m Omnistor if you are interested,
Cheers, Dave(n)
Nigel&Debbie
Nigel&Debbie
322
212
Full Timer
Autotrail Dakota
since Jan 2013
Cheers, Dave(n)
We have a 4m Omnistor canopy :(
Nigel&Debbie
Nigel&Debbie
322
212
Full Timer
Autotrail Dakota
since Jan 2013
We have a 50-50 split opinion so far.
Would have thought this was a common issue. What do others think?
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
Generally it is not a good idea to have an enclosed space into which a gas burning device is pushing its exhaust fumes, however low the rate of combustion may be.
In the wrong conditions of combustion it is possible to generate Carbon Monoxide from the appliance, which is a killer.
That's it really, I'd be happy with a fridge venting in there as it is a tiny flame, but once you start using it for a water heater or warm air heater exhaust I'd say it was dangerous.
Peter
Jul 29, 2013
9,071
18,520
Salisbury
Hymer B678DL A class
since 2011
I did query this with Autotrail and they told me that as far as they were concerned there was always enough airflow around the safari room and it shouldn't be a problem.
I personally am not comfortable with that as there is still fumes being expelled into the area and could get into the van as well.never did get a straight answer from them
Nigel&Debbie
Nigel&Debbie
322
212
Full Timer
Autotrail Dakota
since Jan 2013
We have an autotrail and are awaiting a reply from them. Its been 8 days so far. Will update post when and if I get a reply.
As people will has assumed, I have concerns. What I can't understand is why they design the vehicles in this way in the first place. Do the actual designers ever actually use what the design or have they ever actually used a motorhome?
Jul 29, 2013
9,071
18,520
Salisbury
since 2011
No I don't think they do and even when it's flagged by buyers they don't even come up with a safe answer,I did think about a flue extension but I don't think it would be possible on a balanced flue unless someone can tell us differently.:xThumb::groan:
Mar 3, 2013
1,485
6,163
Poole
There are plenty of gaps with a safari room, they never fit flush and the air circulates quite well. Should be no problems.
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
If the price is right may consider extending front panel
Hi, Nigel&Debbie, sorry for delay in replying to your post, . The S/R has only been used a few times and is in excellent condition, it also has a set of curtains with it, Asking £150.00 for it FQS
If you are interested please let me know before I put it on ebay.
We are away until 11 Jan.
It is a genuine Omnistor.
Cheers, Dave(y)
