Awning options (1 Viewer)
paul18
171
34
Somerset
C class
newbie, but was caravanner for 20 years
I have had a search but can't quite find what I am looking for, so apologies if It's there. I have an Ace Modena 2004 with no wind out awning fitted. We want a smallish porch awning and like the look of the Kampa 260. Our van appears to have a caravan awning rail but with no access points for the beading, so I am guessing it's only trim. What are my options please? I've seen big awnings with throw over straps but don't like the idea of that flapping noisily at night. Can you fit just a awning rail or would we have to go for a wind out?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,563
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Very easy to make extra awning access points in awning rails
drill small file and a pair of long nose pliers
Drill 10mm hole flare out slightly the newly formed edges and file smooth
paul18
paul18
171
34
Somerset
C class
Very easy to make extra awning access points in awning railswhy no access
Is it safe to do this, it would be an ideal solution as we don't go out it the van once sited. We walk or bike. Doing this wouldn't damage the seal? Someone told me it's not proper awning rail just trim, hence why no access points?
DBK
17,968
47,804
Plympton, Devon
PVC, Murvi Morocco
Might be worth posting a photo of it so folk can be sure what it is. :)
Geo
Trader - Funster
Jul 29, 2007
11,757
14,563
Mansfield,Notts
I would have no hesitation in doing it if indeed it was an awning rail i was working on
But some folk didnt ought to let loose with a knife and fork
It all depends at which end of the spectrum you reside
If in any doubt dont do it simply afix a second rail below the existing trim
if what you have has no cut out are you sure you are looking at an awning rail a pic says a thousand words
g
paul18
paul18
171
34
Somerset
C class
paul18
paul18
171
34
Somerset
C class
Not awning rail then? How do I fit a rail below as you suggested? ,would it involve drilling? If so I may as well get a wind out fitted?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,563
Mansfield,Notts
Very few Motor home awnings actualy fit at the side like a Caravan awning does inside a rail
some do have a single straight rail at the top fed from either end and elasticated poorly fitting sides
Hence why they invented the strap over the roof
Ive never heard anyone complain of Flapping noise
Geo
Trader - Funster
Jul 29, 2007
11,757
14,563
Mansfield,Notts
Yes it will involve drilling for a secure fix some may advocate adhesive fixing but not me
paul18
paul18
171
34
Somerset
C class
Thanks for your time Geo. Answers my question perfectly I think
Geo
Trader - Funster
Jul 29, 2007
11,757
14,563
Mansfield,Notts
going offline for a few hrs so excuse me
But many on here offer good advice not all the same advice thankfully so have a good read pick out what you like and go for it I to would go for a wind out it kinda finishes the package off properlyand open up more options for privicy rooms, wind blockers, and simple sun shades
G
DBK
17,968
47,804
Plympton, Devon
PVC, Murvi Morocco
Just had a look at your profile and it say something along the lines of "caravanner for many years." If you've only just got the MH I suggest fitting a wind-out awning and don't bother with what I might call a caravan type awning. Very few folk use these on MHs although they do have their place, for example if you need somewhere dry for say a mobility scooter. Otherwise I suggest give a wind out awning a good try before you think you need anything extra. For me the attraction of motorhoming is the easy with which you can move from place to place. Once you start faffing about with awnings, waste hogs etc then you are getting close to being a caravanner again. Not that I am condemning these extras, but give the "minimalist" approach a try first then get extra stuff if you think you need it. If you are going to say pop over to France and use the aires then you won't need any sort of awning in most places and in the heat of summer a conventional caravan type awning will be far too hot.
paul18
paul18
171
34
Somerset
C class
Well not beginners any more I suppose, approaching 2 years moho ownership, but 20 years worth of tugging. We are pretty minamilist but want storage more than an thing else, but no intention of leaving UK
Reactions: DBK
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
If it's the Kampa Rally Ailr Pro you fancy then you may like to check out @scotjimland posting. He added an awning rail specifically for the Kampa awning. It was a simple task and his post has links to the parts and pictures etc.
Reactions: DBK
paul18
paul18
171
34
Somerset
C class
I've read somewhere about a kador strip with figure of 8 connectors. Anyone know what this is about?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,563
Mansfield,Notts
All you ever wanted to know about Kader strips, But I cant see why the Orange bit wont go straight into an awning channel personally.
Although I do know a the figure of 8 strips were used im my earlier days to join an awning to a roof gutter on self builds and smallish VW type 2s etc
The bottom pic shows how you would connect to your new windout, should you want to.
You roll out the awning to within reach, slide in awning, then wind back up again, it acts like a built in awning rail, when the awning is not in use you can then use the wind out fully deployed as a sun shade
Fun aint it:doh::banghead:
1,372
4,148
Cheshire
Van Conversion
Been around the block a few timesšŸ˜‰
As link above but we found it was a real pain to connect the Driveaway to the wind out awning & just kept the awning free standing.
11,518
43,712
Cornwall
Ducato PVC
Getting Better
I was looking at an awning and I already have a wind out, but I am now looking at something like this from Argos and other stores... I'm parked next to someone now that has one and he has used it a lot in the last few years and it still looks good....
Trespass event shelter... About Ā£140 on the net...
