Awning on PVC
Discussion in 'Motorhome Chat' started by Murphy, Aug 21, 2015.
  1. Murphy
    Murphy Funster
    Jan 31, 2015
    92
    52
    Mansfield
    We are looking at a PVC and require one with an awning, not fussed if Fiamma or Thule, they tend to be corner roof mounted,
    My question is can these awnings be slid across on their brackets to enable an air awning to be placed through the awning channel where as the left up right sits between the cab door and sliding door,
    Noted on a lot of vans that the left end of the awning is on the edge of the sliding door,
    Anyone had this issue and rectified ?
  2. Cal54
    Cal54 Funster Life Member
    Apr 25, 2014
    1,457
    9,089
    Lancaster
    Had an awning from a prev MH which for the life of me we couldn't get to fit on my current PVC. It was the right length and height but always fouled on the sliding door. On mine the Fiamma canopy casing is directly in line with the left hand side of the slider and always caught the material. Sold it and now have a pop up day shelter from Quest which is the 'bees knees'.
    Good luck in your search!
    • Like it Like it x 1
  3. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,936
    12,190
    Plympton, Devon
    The brackets on my Fiamma awning could slide along the awning a bit if you drilled new holes through the awning rail. The limit would be how much leeway you have depending on where the brackets are fixed to the roof.
    The left hand end of the awning on mine is directly above the rearmost edge of the passenger door. So it is already in the place where I think you want yours to be. I suspect most awning won't be far off otherwise they wouldn't cover the side door so any sliding needed shouldn't be too far.
    But as above, how the awning copes with the side door opening is perhaps the biggest issue.
    You can see how mine is fixed below. Note it could move backwards much further than I could move it forwards. There are also of course things inside the rail which would limit the adjustment. I can only suggest wind the awning out on a vehicle and have a peek inside and see what would be possible.
  4. berni109
    berni109 Funster
    Sep 10, 2012
    320
    279
    worcester
    Think it depends which base van and which awning.
    On my fiat base PVC the awning brackets are fixed to the roof rack fixing points and then there is some fore and aft movement. I would think that the fimma on mine would be in exactly the place u want the awning to go.
    Hth
  5. Murphy
    Murphy Funster
    Jan 31, 2015
    92
    52
    Mansfield
    Thanks all for your repays, very much appreciated,
    Think I will need to take some step ladders with me when viewing vans, to ensure the flexibility in sliding the awning is there, if it's needed
  6. Mikeco
    Mikeco Funster
    Sep 26, 2013
    732
    543
    Market Rasen
    Interesting that you appear to have used an awning which is not the one made for a PVC, the correct one such as the Fiamma F65s has brackets that fix to the existing lugs on the roof, it also then sits on the roof and is flush with the side of the van. Was this intentional or did somebody not know what they were doing.
  7. John Laidler
    Jan 9, 2013
    8,936
    12,190
    Plympton, Devon
    It is the factory fitted one! I guess they use this model so it leaves the fittings free for roof bars - which ours had when we got it although I subsequently took them off. Although it sticks out it doesn't make the vehicle any wider as the sides curve in towards the top. But I guess the F65 is a good model for after market fitting as there are no holes to drill in the vehicle.
  8. Milliemobile
    Milliemobile Read Only Funster
    Jun 26, 2014
    889
    1,027
    North Yorkshire
    Our autorail V-line came with factory fitted awning/sun canopy on and we have attached a Vango air tall drive awsy awning easily to it as per our avatar.
    Previous pvc was a bespoke from Shire conversions and they added an awning/sun canopy, we never tried using a drive away with that van but we could have if wanted too. Depending on age of a pvc would hope any fixed awning/sun canopy would have been placed to allow use in conjunction with a full awning.
    Lin :)
  9. Murphy
    Murphy Funster
    Jan 31, 2015
    92
    52
    Mansfield
    What make of van is this out of interest?
  10. John Laidler
    Jan 9, 2013
    8,936
    12,190
    Plympton, Devon
    Murvi Morocco.
  11. Cal54
    Apr 25, 2014
    1,457
    9,089
    Lancaster
    @Milliemobile, my 2013 PVC which has a factory fitted Fiamma F65s canopy certainly doesn't appear to be installed with the option to fit an awning, in my opinion. I'm not saying there isn't something suitable out there just that what I had didn't work and I prefer my pop up.
  12. Mikeco
    Mikeco Funster
    Sep 26, 2013
    732
    543
    Market Rasen
    You can fit a 2 bay awning as used on many caravans but you need to make sure that you get the correct one for the height.
  13. John Laidler
    Jan 9, 2013
    8,936
    12,190
    Plympton, Devon
    Does it not have the two slots in the rail?
  14. Milliemobile
    Jun 26, 2014
    889
    1,027
    North Yorkshire
    On ours it just requires an additional awning fixing strip, sold independent to the awnings, which come in various fittings, one side sliding into the wind out canopy, on ours its a groove that it slides into. Then other side slides on the awning. Maybe not all wind out canopies come with the recess groove? Both of ours have it.
    Lin :)
  15. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,716
    10,147
    both fiamma and omnistor/thule canopies include an awning slot on the front edge. some 4mm some 6mm bead size
  16. TheBig1
    Nov 27, 2011
    7,716
    10,147
