Awning legs - advice (1 Viewer)
Dare_Devil_Dennis
296
199
Derby
Newbie
I have a factory fitted Thule wind out awning on my swift MH and supplied with it are a set of clips for fastening the legs to the body of the motorhome.
This model Swift has the GRP side panels this year and I wonder if I should drill the body and fit these clips so they can be used with the awning partially deployed (like to keep rain off the door area).
I consider myself to be a fairly competent engineer and could easily do this without compromising the integrity of the side panel. I would consider using a small spreader plate outside and a similar pate on the inside to beef it up and help with sealing.
The Swift handbook says it is not recommended but does not say why. so why supply the parts?
Anyone know of or experience problems with this approach?
Sep 26, 2013
4,169
5,154
Market Rasen
Self Build
Since 2003
I fitted mine to a Burstner we had a few years ago, I put them on a bit of sealant and used short self tappers which did not go through the inner skin. This worked fine as the load is pushing onto the van.
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
I have the same spare bits.... And often pondered.... However, if it's raining and I only want a "shelter"... 3' and legs vertical works....
The only issue would be .... Say on Tarmac etc or where ground is too hard to peg.... But as yet I've not faced that issue....
So... I've resisted ... On the same pretence as you... I.e... Manuf not recommendo!...
Billggski
114
63
Stone
Overcab
Newbie
It's also very useful with dogs, they don't wrap their leads around the legs and bend them. (How do I know?)
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
I use these all the time. Mine are Fiamma and they come with a plastic plate that goes on the inside wall so you do need access on the inside. Both mine line up with outside lockers so fitting them is a cinch.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I am doing EXACTLY that same thing tomorrow, I will glue it with remnants of my sikoseal and use the self tappers to hold them whilst it goes off, leave them in of course afterwards, belt and braces, I think the screws would be OK, but well I have some SS left over from other thing and it is going to set in the tube anyway.
Lenny HB
53,420
149,939
On the coast in West Sussex
Hymer B678 DL
Your van like Hymer,s has a closed cell foam core so no problems, don.t know whats in a Swift if it's polystyrene I wouldn't risk it.
Dare_Devil_Dennis
Dare_Devil_Dennis
296
199
Derby
Newbie
Mine has a solid foam laminated to the grp outer skin and the inner wall. I like the comments about the dog leads. never thought of that. Don't know why - had enough of that with caravan sun canopies.
