Awning Factory Fitted
Discussion in 'Swift Motorhomes' started by Supertractorman, May 4, 2009.
  1. Supertractorman
    Supertractorman Read Only Funster
    Sep 7, 2007
    While washing the roof of my 2006 Bessacarr E795 this weekend, I was checking all roof fittings and found that the curved strip over the top of the awning was loose at one end.
    It is held in place by 4 sets of 2 screws which are screwed into angle brackets which are bonded on to the side of the van.
    After removing I found that not only the bonding had failed on the end bracket, but also on a middle one, so the strip was only held on by two brackets. I repaired by putting screws through the brackets to secure.
    I am posting this as if all had broken away, then the flying strip could have caused harm to a passer by if flapping about or coming off, so it is worth a check if you are on the roof of a Swift with a factory fitted awning.
