Awning channel reducer
Discussion in 'Tech/Mech General' started by Peter S, Sep 8, 2009.
  1. Peter S
    Peter S Funster
    Jul 20, 2009
    47
    3
    Towcester
    I have purchased a free standing motorsport awning which has, what appears to be 10mm beading, which normally goes into a piece of alu extrusion. In some applications this extrusion would then be attached to the side of a mhome or van. I want to "butt" the awning up to my fiamma F45I and put the top edge of the motorsport awning into the channel on the front of the fiamma.
    However, the fiamma channel is about 6mm so I need some sort of adaptor ie a piece of 6mm to 10mm channel or strip.
    Anyone any ideas who would do sucha thing? All I have found is the fig of 8 stuff which won't do the job.
    Pete
  2. chrisboyo
    chrisboyo Funster
    Aug 5, 2009
    1,338
    825
    Newport South Wales
    Hi there
    I had the same problem
    Riversway do an adaptor strip for £16-£17
    One edge 6mm goes onto the wind out rail and the other 8mm, goes into the fig 8 strip, and then your awing goes in to the other edge of the fig 8
    That sounds compilcated ! but very easy to do and works well
    You have to specify either Omnistore or Fiamma
    Happy Daze
    Chrisboyo
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,265
    5,250
    East Sussex 01-580-881288
    Hi Pete,
    This is what you need:
    Fiamma/Omnistor Drive away fixing kit OR532.
    Designed so one side of the fixing kit slides into the channel at the front of a Fiamma/Omnistor wind-out awning.
    (Fits, Movelite XL Nomad 3, Nomad 2+2, Navigator).
  4. Peter S
    Peter S Funster
    Jul 20, 2009
    47
    3
    Towcester
    Brilliant - thanks. Will buzz them tomorrow.
  5. Peter S
    Peter S Funster
    Jul 20, 2009
    47
    3
    Towcester
    Makes sense - thanks:thumb:
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    cant help peter, but the fiamma channel needs a 4mm bead......6mm is too tight and will only go in a few inch's then jam solid.
    in know 'cos i bought the wrong awning driveaway kit with a 6mm bead on both edges.
    i believe the american windout awnings use an 8mm channel
  7. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,265
    5,250
    Give us a ring and get your Funsters Discount:thumb:
    Peter
  8. Peter S
    Peter S Funster
    Jul 20, 2009
    47
    3
    Towcester
    Will do:Smile:
  9. Peter S
    Peter S Funster
    Jul 20, 2009
    47
    3
    Towcester
    Wow thats tiny - thanks for the tip
