awning 'C' rail length (1 Viewer)
Fishman
29
12
Stockport,Cheshire
Autotrail Cheyanne 630LB
since April 2009
:Sad: Help I' want to fit an awning 'C' rail to my van but can only find it supplied in packs of 3 x 1.2 metre lengths my awning is a Kampa 390L which leaves a shortfall of 30cm does anyone know if it can be bought in different lengths
or singletons of the above Many thanks in anticipation Fishman
Dec 6, 2011
11,470
25,067
South Wales
Coach built Adria
hi, thinkin of doin the same only i have the Kampa 260 so less of an issue but would prefer a single lenght.:thumb:
also as a thought the 390 is actually longer than 390 as it has end pieces which sit in the rail by about an extra 200mm either side ( the 260 is the same ):Eeek:
scotjimland
2,090
9,060
Suffolk Coastal District, UK
Timberland
I bought a 4mt length from a local caravan dealer/repairer .. so it can be found, but maybe not on-line due to shipping restrictions..
lunarman
2,147
2,438
South Glos
since 1994
Firstly have you measured the length of the beading on the awning it is about 4.2 mtr long, because of a strengthening web, so you need a channel of that length.
I had the same problem finding rail and did eventually find it in 3 mtr lengths so I only have 1 join. I hope that you have the aluminium rail and not the plastic one as I found that the beading of the 390l would not slide in the pastic as the hole is smaller than that in the aluminium version.
To make sure that the awning did not snag on the join I filed a corners off of the join. Also as I had 2 x 3mtr lengths I put a longer rail on than was actually necessary so that I have flexibility in the positioning of the awning.
Lunarman
lou020
488
355
huddersfield
autotrail chieftain
since 2010
i bought 2 x 3 meter alloy lengths last weekend from my local caravan dealer,it was in the accessory shop just over £8 per length.:thumb:
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
That was a good price:thumb:
As other say, check out the caravan places, we have a Chichester Caravans near us and they had 3m ish lenghts, bit more than £8 though, £20ish if memory serves:Doh:
Fishman
Fishman
29
12
Stockport,Cheshire
since April 2009
Fishman says thanks
A big thankyou funster you never fail. Will get mobile and track the rail down
(pardon the pun)::bigsmile:
