Minxy
- Aug 22, 2007
- 32,623
- 66,459
- Carthago Compactline
- Since 1996, had Elddis/Swift/Rapido/Rimor/Chausson MHs. Autocruise/Globecar PVCs/Compactline i-138
Avtex TV digital aerial, little used but works well (we just watch pre-recorded stuff when away so don't use it now).
£20 + P&P
Boxed - all the pieces are in the box - the box is a bit 'battered' but still usable to store it.
Blurb ....
£20 + P&P
Blurb ....
- Designed for caravans and motorhomes the Avtex STH1000 Digital Antenna is lightweight, compact and very easy to use. With its unique flexible mounting system the STH1000 can be installed indoors or outdoors in seconds.
- The STH1000 has an integrated 20db amplifier which can be powered by the antenna power out function found on most set top boxes and all Avtex digital televisions. Alternatively you can use the 12 volt dc power inverter included. Enjoy crystal clear digital reception with the STH1000 complete antenna solution.
- This Aerial is supplied with a universal flexible suction mount, clamps for pole mounting and a permanent screw on fixing bracket.
- Weighs just 875 Grammes in the box
