Avtex Snipe will not Park (1 Viewer)
Sir Bradley
Aldershot
Caravan
I had my Snipe fitted at the Newbury Motorhome Show 2014. It has worked OK until Christmas Eve. When I turned it on after arriving on a CL, All the lights started flashing and the dish went intermittently up and down, but at no time did it go to park. At no time did I get it to do anything other than as above. Any ideas how to fix it or how long the warranty is as the paperwork doesn't say.
Jul 27, 2007
204
179
West Yorks occasionally
Swift Bessacarr 560L
I had a problem on the main board. A motor-home workshop tried taking it apart and re-aligning the servo shafts, but I think they ended up making the matter worse with damage to the shaft bearings. The panel just flopped around after that.
The whole unit ended up having to go back to Avtex Ltd. Unit G5 Capital Business Park, Parkway, Cardiff. CF3 2PX. 08448806161 www.avtex.co.uk
They charged £150 +vat for a new board, but they did give it a good overhaul. If you send back the controller with it, make sure it is recorded- they forgot to send my back.
You will be out of warranty now but you can always argue .
Is there anybody else around with a Snipe. It may help if you can determine if the fault is in the main unit or the controller end.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
I found the original problem was that the screws that hold the arm part to the motor were all loose. Check to see if there is any play in the arm.
Lenny HB
53,421
149,945
On the coast in West Sussex
Hymer B678 DL
Had a problem with mine parking, not quite the same, it would go down, but motor kept running sounding like the belt or gears were jumping. The fault was the back of the dish was not contacting the switch on the base which turns the motor off. Avtex changed mine, it would have been an easy diy fix.
