Avoiding damage to driveways (1 Viewer)
MattR
4,104
38,849
Beds
Panel van
Years
We are staying on a block pave driveway tomorrow night. Our hosts have asked whether there is a risk of damage to their drive.
We have a Merc Sprinter 312 (weighing in at around 2900 kg loaded up). What is the likelihood that a driveway will be damaged by 1) driving over it and 2) parking on it?
I have cut some boards to put under the tyres in case we are likely to damage the drive when parked up but they won't stop damage as we maneuver onto it and I don't really want to lug them about if the risk is minuscule. If they are needed, what size do they need to be?
Jun 2, 2010
4,924
11,290
Flintshire
Low profile
since 2010
Block pavoir is as solid as houses once set and sanded in, Roman roads were built that way and some are still around:thumb:
Jan 10, 2013
5,958
7,354
Near Uttoxeter and Crete
Warwick XL PVC
Still trucking and learning
If you had a LandRover Discovery would they be asking if that would damage the drive? With 4 passengers and some luggage this would virtually equal the weight of your van. Think they may be being over cautious.
Weight of LandRover Discovery excluding passengers:
Kerb weight5,333 lb (2,419 kg) - 5,426 lb (2,461 kg)
Southampton
522
318
Hampshire
Since 2009
I have mine (4500kg semi-loaded) on our block paving and it is no problem at all. If it was constructed properly then I don't think there will be a problem.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
My 5 ton camper lives on block paving when at home with no problems.
Aug 30, 2012
4,270
11,305
Home of the war horse
burstnar T640
If it been laid correctly then no
But on ours I park on 2 by 2 ply under each wheel just in case
With a load of 1 ton each wheel works out at about 2.8 ton per square meter as against about 70 ton per square meter on tyres
Big difference ?
SPUD'N'T
190
4,318
YORK ENGLAND
COACHBUILT (LOW PROFILE)
since 2008
mine is based on a 315 sprinter & weighs in at 3.85t, we have a block paved drive which it stands on when not in use (since 2009) No signs of damage to the drive as yet
lorger
9,661
90,507
Dumfries
Knaus Sun 650MEG
I park mine on my dads when i want him to wash it and so far no problems apart from he cant reach the high bits but thats to do with his height not the paving :ROFLMAO::ROFLMAO::ROFLMAO:
MattR
MattR
4,104
38,849
Beds
Panel van
Years
Thanks for all of your quick replies - reassuring to hear. I also think that they are being over-cautious but wanted to check.
On a similar note, I'm trying to get hold of some old bread crates but no luck so far. Any suggestions as to sources? We've spent a few nights on grass pitches / fields and sunk slightly - we want to avoid that particularly when it is wetter.
Aug 30, 2012
4,270
11,305
burstnar T640
Back door of morrisons :ROFLMAO:
lorger
9,661
90,507
Dumfries
Knaus Sun 650MEG
I got a couple from my local baker as he had a few broken ones, so pop in and ask him or if your up early and see the delivery driver ask him im sure for a couple of pound he might help you out. if not you can buy them on ebay.
Jan 18, 2010
538
138
Airdrie Scotland
6 years and 20 years as a tugger
If constructed properly no problems I have a friend who has a works van and has clearly damaged his driveway
MattR
MattR
4,104
38,849
Beds
Panel van
Years
I'll see if I can get to a bakers - the only ones on Ebay that I have seen are in bulk lots - too many for my needs and too far to drive to try and arrange just to buy a couple.
Our neighbours' drives have damage caused by vehicles but we live on almost solid clay so there is loads of natural movement of the soil and it is not uncommon for drives to get deformed. I hope that our hosts have been a bit more selective with the people that built their drive as well (we have suspicion that one of our neighbours was tempted by the "special offer" given by the door-to-door sales person offering to do the work for them) but will use the wooden boards just in case.
Jan 10, 2012
148
107
London
I'm a newbe
Block drive ways
I have had a 20 ton Grab lorry on mine along with it turning round when I built an extension and not a single block broke, turned or showed any sign of damage.
So if a drive has been put down correctly you should have no problems at all.
Also my Rapido gross weight 3800Kg lives on the drive without problems.::bigsmile:
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
I have a Land Rover discovery that is 2.7 tons loaded and that is always parked on our block drive. Don't worry about it, if properly laid you could park anything on it.:thumb:
Jul 28, 2010
1,710
617
The world
Small car
Right that's it I bringing the jumbo jet around next week. So clear the road so I can get in !! :ROFLMAO::Blush::RollEyes::Doh:
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
No probs. I once drove a Chieftain tank over a block paved shopping precinct in Germany. OK, so they weren't too chuffed about it, but hey, no damage occurred. Admittedly the ground to weight ratio of a Chieftain is pretty low, 1 & 1/2lb per sq inch, but it does weigh in at 52 tons. The secret, I think, is not to move the steering whilst stationary, just in case you shove the paving to one side. Drive on straight, and off the same way. ::bigsmile:
Sep 26, 2013
4,169
5,154
Market Rasen
Self Build
Since 2003
It's not really much good when people say that they have parked on block paving with no problem. Unless you know how the drive you are going to was constructed then you have no idea until you park on it.
If the block paving was done when the house was built then there's a good chance it was done properly and you will not have a problem, if it has been done by jack the lad at a later date then who knows.
Mike
daisy mae
675
597
Leicestershire
C class Coachbuilt
I`m a newbie, now 1 year
Block drives are just that drives, we have one no problems, if it was done as a drive it should be up to the job.my MH is 3.300k
