Auxillary power (1 Viewer)
durhamahoy
241
116
Durham
Since 2011
Hi,
Just been away this weekend and thought I would give 'Auxillary' power a go.
Lights seem to work, but not sure about the fridge? set the rocker switch to auxillary and the fridge to battery but no light came on? does this mean the battery might be on it's way out or a fuse problem?
Hope someone can help me understand a bit better.
TheBig1
17,617
43,187
the fridge is designed to only work off the battery whilst the engine is actually running
durhamahoy
durhamahoy
241
116
Durham
Since 2011
Hi,
I did try that as well but the rocker switch still didn't light up?
Thanks for the reply
Steve
TheBig1
17,617
43,187
the switch doesn't light up on 12v and although it can keep a fridge cold, it wont chill it down like on gas or 240v. its much the same as those fitted in caravans, it only keeps it cold whilst you travel
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
TheBig1 is right here, however, if it doesn't work when the engine is running check the fuse, if that's okay, check the bulb in the rocker switch.
When on 12v it won't be anywhere near as efficient as with gas or 240v hookup. It will also be very quiet so I wouldn't be listening out for the condenser. Hope it turns out to be just the fuse for you. Lance :thumb:
