auxillary airel inputs
Discussion in 'Motorhome Chat' started by Scout, Nov 11, 2009.
  1. Scout
    Scout Funster
    Apr 4, 2009
    3,297
    8,603
    doncaster
    seen a m/h with side fitted duel auxillary tv input, one input for co-axe one input for satalite screw type fitting, are they easy to fit, were can you get them?, whats the proper name for them?
    thanks
  2. bevo
    bevo Read Only Funster
    Nov 15, 2008
    218
    north west
    satellite socket
    i fitted one of those (maxview).
    it's just 2 holes for the coax cable, and 2 little holes for the self tapping screws.
    make sure you can access the holes from the inside when drilled, to pull the cable through,
    put loads of sealant on the cable from the outside and as you feed it through the sealant blocks the holes.
    there is also a watertight gasket with the socket.
    in my opinion easy peasy, just have to have the confidence to drill into the van.
  3. Scout
    Scout Funster
    Apr 4, 2009
    3,297
    8,603
    doncaster
    thanks just looked it up, it seems easy I'll have to explore the van wardrobe:thumb:
  4. hilldweller
    Dec 5, 2008
    27,179
    26,153
    Macclesfield
  5. bevo
    Nov 15, 2008
    218
    north west
    external socket
    hi seb
    forgot to mention i also fitted an internal socket on the inside ( bought from wikinsons store) that has the same connections as the outside (f screw type connector and coax connector) so its a simple job connecting and changing connections on the inside.
  6. Scout
    Scout Funster
    Apr 4, 2009
    3,297
    8,603
    doncaster
    I was going to do that, on the TV cable side I'll try to pick up the airel lead from the statas power amp & airel which runs through the inner roof liner, that way I can also back feed the signel to the onboard freeview box for the front screen and get the four speaker sound from the radio dvd player and both tvs sinced up togeather. I'll have to have a good look at the onboard stuff to make sure I dont back feed into the amp though, might cause a bang :Eeek:
  7. Scout
    Scout Funster
    Apr 4, 2009
    3,297
    8,603
    doncaster
    thanks, but the one I need the maxview, gives both tv co-axe and satalite F conectors,
    nice handy site mind, the power out socket might come in usefull:thumb:
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,883
    17,542
    YO11 2BD
    i fitted one INSIDE the side locker.....the external coax cables enter at the bottom of the locker door at a slight angle (diagonally horizontal).
    the rubber seals have enough 'give' to accept the cables and reseal around them.
    no hole drilling in the van walls or sealing needed:thumb:
