autowatch 161 alarm help. (1 Viewer)
Khizzie
3,794
5,695
Le Repaire,Thiviers,France
Autocriuse stargazer
since 2002
Hi having a problem in identifying what the separate little fob does ,this just seems to push into a receiver on the dash ,not wanting to mess anything up ,also the magnetic ?? Door sensors have a little press button on them does this switch them on and off ?? Sorry to be so dense but even on handover it was not explained and because its a used vehicle only got the basic info.
43,323
49,437
That little fob is an emergency over-ride for the remote fob if lost or the battery goes flat.
Touching it to the small pad turns off the immob and alarm which, i believe, resets automatically when the ign is turned off again.
My door sensor is wireless and doesnt have the button but i suspect it could be a test button to show its working as it should or maybe to check the button cell battery is ok.
i also have a wireless internal PIR which works when it wants, as does the magnetic door switch.
To be honest i have never seen such a poor quality alarm.
Khizzie
Khizzie
3,794
5,695
since 2002
Brilliant papajohn, that explains everything .and coupled with the link I got from Gizmouk I zm well on the way of understanding the system.thanks again to you both.
