Autotrail Wall Lining Spares ! I Think!
Discussion in 'Motorhome Chat' started by zac, Apr 28, 2016.
  1. zac
    zac Funster Life Member
    Nov 19, 2013
    731
    240
    Hampshire
    I am in need of what looks to be a piece of wall covering where the rear tv is situated where a very small area has come off when peeling off a piece of double sided velcro. It looks as though this stuff is just stuck to the walls in a sort of wood effect. Does anyone know where i can get a tiny piece just to put over this mark, it is annoying the hell out of me ?
    Motorhome is Autotrail Delaware 2015 Model
    Not tried autotrail yet as i expect it will be a few hundred quid from them as they always like to keep their prices low NOT.
    Any help appreciated.
  2. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,509
    2,082
    Scotland
    Is it timber effect veneer or the wall "paper" you're looking for?
    If the former you can get matching screw head stick on vinyl covers.
    If the latter, would a piece of the matching jointing tape used to cover the board joints do? If so, you can get rolls \ cuttings of this. Or, could you carefully remove a hidden piece and use that to cover the tear?
  3. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,434
    7,723
    2015...... Guarantee... Let the dealer / Autotrail sort it out..
    I know it may be a pain but at least lodge the faulty with AT customer services and see what they say..
    • Like Like x 1
  4. zac
    Nov 19, 2013
    731
    240
    Hampshire
    Not sure it looks as though this stuff is just stuck on but i may be wrong, it looks like a wood effec. Would need to be wafer thin though if possible
    This time it is not there fault as i caused it when i peeled off the velcro, it is only small so not major but i could do with something to cover over it as i always look at it now
  5. Mikeco
    Mikeco Funster
    Sep 26, 2013
    638
    432
    Market Rasen
    Sounds like you have pulled off the top layer of the lightweight board that is used, it will be difficult to repair so make a feature instead. Larger TV perhaps or even a Fun sticker
  6. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    1,875
    1,624
    Bungay Suffolk
    As said,, get the manufacturer involved..
  7. Gellyneck
    Jun 5, 2014
    1,509
    2,082
    Scotland
    I got a sheet of "screw head" covers (not the best of photos) from the supplying dealer -
    Have a look around your van as they are used to cover what would be exposed screw heads and you'll see how they look. They are paper thin and blend in quite well.
    Another option may be to go to an art shop and get a coloured crayon \ pencil \ felt pen that closely matches the damage and camouflage it?
  8. Mikeco
    Mikeco Funster
    Sep 26, 2013
    638
    432
    Market Rasen
    You don't say what the colour is but if it's the popular Maple or light oak then you can buy a 7ft x 4ft sheet at 3mm thick for around £25, this could be stuck over the entire wall.
  9. Gellyneck
    Jun 5, 2014
    1,509
    2,082
    Scotland
    Don't know what the 2015 colour is but 2013 is some type of cherry, from memory. I got samples of light oak and maple and neither were a good match however if you are doing the full panel it may look ok.
    Google self adhesive vinyl (or in the words of Blue Peter sticky backed plastic"!).
  10. zac
    Nov 19, 2013
    731
    240
    Hampshire
    That looks the same color, can you buy these?
  11. Gellyneck
    Jun 5, 2014
    1,509
    2,082
    Scotland
    I got the sheet from my supplying dealer (foc as some were missing) so would assume they will be able to supply to yourself. They should be able to colour match on your year \ model. Price? If your close to the dealer might be worthwhile toddling in to see if they've got one or two kicking about.
    The "dots" are about 3/4" in diameter.
  12. zac
    Nov 19, 2013
    731
    240
    Hampshire
    I will ask them next time i am there as they are 4 hours away from us which is a nuisance.
    Thanks anyway.
  13. Gellyneck
    Jun 5, 2014
    1,509
    2,082
    Scotland
    Just a thought.
    Have a look in your garage \ under the double bed on your Delaware you might find a screw head that's been covered by one of these "dots" that you could carefully peel off using a razor blade \ craft knife and use inside. One missing in the garage would be less intrusive for you than the damage on the wall.
    Our Savannah has the garage screw heads covered.
  14. zac
    Nov 19, 2013
    731
    240
    Hampshire
    Thanks i will take a look later to see if there is one there. Never looked to be honest, might be a good tip.
