Autotrail radio
Discussion in 'Tech/Mech General' started by Carreraboy, Oct 13, 2012.
  1. Carreraboy
    Carreraboy Funster
    Nov 6, 2011
    28
    12
    Gloucester
    Have decided that I can no longer put up with the standard fit Autotrail radio losing signal and constantly seeking channels. Not sure if this is the radio or aerial but would like to replace with a double DIN unit which would also give a better image from the reversing camera.
    Has anyone fitted a double DIN unit into the Ducato and if so is it a relatively
    easy job? Also any advice for upgrading the aerial would be gratefully received.
    Kevin
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,422
    5,451
    East Sussex 01-580-881288
    It will be the lack of a decent radio aerial, common fault
    Peter
    • Like it Like it x 1
  3. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,323
    8,030
    West Norfolk
    A friend has the same problem.......:cry:
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,268
    17,931
    YO11 2BD
    I agree with Peter.
    depending on the base model variant and year it may have had a roof aerial.
    obviously removed to fit the overcab bulge and the coax just cut off.
  5. Dubiousp
    Dubiousp Read Only Funster
    Jul 3, 2012
    233
    45
    Hampshire
    Just sorted mine on the boxer its been doing my head in. I ordered a combined FM/DAB aerial from DAB on wheels with the intention of mounting on the roof and threading cables through, this was gunna be a night mare.
    On the Boxer both sides below the screen is a small GRP panel, I looked at the nearside which is secured by two screws. Drilled a 12mm hole and stuck tin foil to the unseen side for a ground plane screwed aerial in bonded foil to chassis, ran cables through bonnet release grommet
    A near perfect reception
  6. Vic
    Vic Funster
    Aug 1, 2010
    124
    66
    The only answer is an external aerial. Like Dubiousp, I did not want to drill any metal bodywork so I too drilled the nearside plastic triangular part, but connected the aerial to the bolt above the headlight via an earth strap. The original aerial did not work nor did the swift replacement one.
    Vic
  7. beachcaster
    beachcaster Read Only Funster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    Vic would you mind expanding that answer.......I have my 2009 autotrail radio
    vut Im concerned that its part of the DVD television setup which work ok with the drop down 15 inch screen and I dont want to cock those bits up.
    My solution is to carry a portable DAB radio with me while I drive.....works ok but Id like to get the origianal radio to work too.
    barry
  8. Vic
    Vic Funster
    Aug 1, 2010
    124
    66
    Barry,
    I asume (always a mistake) that the radio part of the centre unit has a traditional aerial socket. If it has then my fix should work for you too. The aerial I used was a cheap non-amplified one to see if it was successful before splashing out and fitting an amplified FM & DAB and a DAB radio unit.
    As the part I drilled was plastic, the aerial would not have worked. There are two options here, either build up the underside of the plastic panel with foil/metal plate or as I did, fit an earthing wire between the panel and the base of the aerial, the part that would have normally be against the inside of the wing. The other end of the wire needs to be earth on the van's body. I used the top bolt that holds the headlight after making sure there was bare metal to bare metal contact. The aerial lead was then fed through into the cab via the a stamped hole in the front bulkhead, I used where the steering would go on a left hand drive version.
    This fix worked in picking the chosen channels in the UK, something that the two left hand pod versions did not. I have also tried an amplified disc aerial which did not work for me either.
    In France I could also pick local channels when travelling as I prefer the radio to CDs even though my French is very poor.
    I would have replaced the aerial as stated, but I replaced the van instead, a Bailey 740 which incidently has an external aerial fitted as standard.
    Good luck and lets us know how you got on.
    Vic
  9. jb0371
    jb0371 Funster
    Jul 8, 2011
    463
    402
    Norfolk
    I have the same problem with my autotrail (mercedes chassis), I was going to drill the bodywork, but I bought one of those 12v powered ariel's, used the glove box lamp for the positive and the negative from one of the sun visor's bolt hole. It does take a few minutes for the internal capacitor time to charge but after that the radio seems to work a hell of a lot better and saves drilling the bodywork.
  10. scek
    scek Read Only Funster
    Jan 12, 2011
    134
    81
    Manchester
    Its the aerial !
    Swift have the same problem with their Ducato cabs. Sent back in 3 times to be fixed with a modification and never improved.
    I drilled a hole in the wing and fitted a stumpy outside aerial. Job done and now good reception.
  11. knokinonabit
    knokinonabit Funster
    Dec 28, 2011
    2,483
    2,453
    Stokesley, North Yorks
    While visiting the Auto-Trail factory we were told that the aerial on the Fiat Ducato is in the nearside mirror and costs over £300 to replace.
    I don't know what age vans this goes back to, but it is apparently fitted to all of the new ones.
    So make sure you protect those mirrors :BigGrin:
  12. Dubiousp
    Jul 3, 2012
    233
    45
    Hampshire
    Interesting nine never made it to the wing mirror a little bit of aerial cable heading that way
  13. jb0371
    jb0371 Funster
    Jul 8, 2011
    463
    402
    Norfolk
    Finally had enough with intermittent radio signal when the engines running, so I fitted an external ariel and still the same perfect when engine off but shite when engine running. I have tried an old stereo that I had in the loft and its still the same so it has to be the vehicle.
    I have looked to see if i need t fit a suppressor but the fault doesnt seem to fit a suppressor problem.
  14. retired2
    retired2 Read Only Funster
    Mar 7, 2013
    south wales
    I recently bought an Autotrail Najavo, 2010 model, and was very disappointed with the radio reception. It has the £1000 Entertainment pack. When the engine was off the radio was fine, but as soon as it was started it became very poor and on the move it kept searching and was useless.
    The last owner had daytime running lights fitted. Very bright lights fitted where the front foglamps could go. While researching the radio problem on the net I came across an American motorcycle website that mentioned that if they switched on their running lights they lost radio reception. I located the fuse for my DRLights and removed it. The radio is now very good on the move locally where it was useless before. I am looking forward to a longer run to test it but am feeling confident that interference from the electronic box for the lights, located under the bonnet, near to the run of the aerial from door mirror to radio, was the cause of the problem. I hope this may be useful for others in the same situation.
  15. Peter & Elaine
    Peter & Elaine Funster
    Aug 30, 2012
    4,035
    6,559
    Roobarb land
    We have a status ariel on ours I think it mentioned some thing about fm in manual and to pull out extenders on top unit
    Can I wire that into cab radio
    Forgive my ignorance if wrong
  16. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,518
    Tyne & Wear, sometimes..
    I too had poor reception particularly on AM on my 2009 Boxer which has a stumpy external aerial fitted on the wing.
    I changed the radio/cd to another with built in DVD etc not particularly because of this problem. That improved reception compared to the original Blaupunkt supplied new with the van, but it was still not brilliant on AM.
    So I now just use the free "Tunein" radio app on my phone, and connect it to the aux input on the stereo. Crystal clear AM and FM channels from all over the country wherever we go.
    No need to change anything. drill, run wires etc buy antenna, boosters, etc etc.....!:thumb::thumb:,
