Autotrail kitchen strip light
Discussion in 'Tech/Mech General' started by GaryM, Aug 20, 2015.
  1. GaryM
    GaryM Read Only Funster
    Aug 20, 2015
    Bushey Heath
    Hi. I'd appreciate yor advice please. The kitchen under cupboard strip light doesn't work in my Autotrail Arapaho (2006). I'm guessing it's just a blown bulb but can't figure how it comes apart to change it. Could someone advise me please. I've tried all ways of getting it apart but don't want to push/pull too hard and break it. Thanks in advance.
  2. PP Bear
    PP Bear Funster Life Member
    Apr 5, 2013
    2,380
    7,240
    UK
    They have a separate switch at the end of the light housing. Check to see if its been turned off first :)
    The covers are a bit fiddly to get off. Look at the one in the shower first, that way you'll see what's needed, before fiddling under the cupboard with limited view :)
    Sounds like the ideal time to fit LEDs, both in the shower while you practice and then the one that's failed (if it's failed). Done all of mine in the AT and it makes such a difference to the light inside and reduces the strain on the leisure batts at the same time :)
  3. Marcus guv
    Marcus guv Read Only Funster
    Jan 31, 2016
    16
    8
    Rhondda
    Have you checked the switch which is on extractor fan? Caught me out on my 2005 scout stripped light down to find no power. Flicked one of switches on extractor fan and on it comes. Why you would have a switch on light and a separate switch is beyond me!! What led lights did you use in yours @PP Bear? Been thinking of this swapped all my spots to led
    • Like it Like it x 1
  4. PP Bear
    Apr 5, 2013
    2,380
    7,240
    UK
    I got all mine at the Crick Boat Show a couple of years ago. I can't for the life of me remember the name of the guy and company, but I've not regretted it one bit. They make such a difference. The only ones I didn't change were above the bed as they would be just too bright :)
