autotrail fridge removeal
Discussion in 'Motorhome Chat' started by rupert, Mar 1, 2015.
  1. rupert
    rupert Funster
    Nov 23, 2014
    118
    117
    leeds
    has anyone had experience of removing the fridge from a autotrail cheyenne ?
    i removed the screws and tried to pull it forwards, but its such a tight fit i'm thinking I've missed something, cos i can't get it. out any suggestions , much appreciated
  2. f6c
    f6c Funster
    Nov 7, 2010
    3,414
    902
    gloucestershire
    Could be stuck in with silicone sealant?
  3. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,188
    15,162
    Leeds the one up North
    Have you disconnected the gas pipe
    • Like it Like it x 1
  4. makems
    makems Funster Life Member
    Sep 23, 2011
    2,707
    10,993
    Ingleby Barwick,,Teesside
    I'm sure you have disconnected the gas pipe at the rear via the outside vent haven't you?
    And there are usually four screws holding it in place.
    When I removed my fridge recently it was a very, very tight fit in the housing and it took two of us to wrangle it out. One pulling inside the van and one pushing at the back through the outside vent.
  5. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,503
    6,484
    West Sussex
    That's normal for a fridge to be a really tight fit, need to try and keep it square with even pressure otherwise you don't stand a chance. Try removing the outside vents and have two people pushing one at the bottom other at the top.
    They are just as hard to get back in, good luck.
  6. rupert
    rupert Funster
    Nov 23, 2014
    118
    117
    leeds
    yep all disconnected ,and I've managed to move it forward about three inches but its getting tighter and i don't want to damage the surround
  7. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,733
    23,157
    Narrfoook
    Watching this with interest.. We have a Thetford fridge freezer in the Chieftain which seems to be somewhat flaky and only works in certain external temperature ranges..
    I suspect in the not too distant future I am gonna have to lob out about a grand ( how bloody crazy is that, the same technology would cost about £250 if it was not motorhome related ) and replace it with a decent one (Dometic )
  8. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,779
    10,192
    you need to use a flat bar underneath to ease it forwards. some can be really difficult
    you also need to disconnect the wires too. a good tip is to take a few photos with your phone to remind you how it goes back
    • Like it Like it x 4
  9. rupert
    rupert Funster
    Nov 23, 2014
    118
    117
    leeds
    well i'm in benidorm at the moment. if its gonna be that awkward to get out, i best leave it till i get home, in familiar surroundings. in case i break summat and start sobbing uncontrollably ha ha
  10. schojac
    schojac Read Only Funster
    Apr 25, 2009
    339
    234
    Cambridgeshire
    There are several possibilities;
    Have you cut through the silicone seal at the rear. This can be accessed through the top vent.
    Assuming that you have disconnected gas, 12v connections the 240 volt wire remains connected until the fridge is removed - is the wire fouling down one side. The fridges do tend to be a tight fit in the carcase but if you have done all the above then as far as I know there's nothing more that will be holding the thing in place.
    Hope this helps
  11. makems
    Sep 23, 2011
    2,707
    10,993
    The wires on ours were long enough and didn't need disconnecting. Just had to cut the cable ties that had been used to keep the wires tidy.
    It is important to keep the thing square as you try to remove it which will be very difficult single handed.
    As others have said though, once the gas is disconnected and the screws removed there should be nothing halo ding it in place except the tight fit.
  12. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,197
    3,027
    Kendal, Cumbria
    Often the screws used to hold the fridge raise the metal around the screw holes. This is sharp and digs into the adjacent cupboards and as well as making it difficult to slide the fridge out can damage the wood surrounding the front of the fridge. I use four slivers of metal cut from a food can to ease the screw holes past the visible wood.
